Old 11-22-2012, 10:21 AM   #1
HIGHFIVEBETA
HIGHFIVEBETA's Avatar
HIGHFIVEBETA is an unknown quantity at this point
Z32 output shafts on s14 open diff?
My brother has a J30 diff he is trying to replace for a welded setup (full track car). The only issue is the axles are j30 5 bolt. Soo can the j30 output shafts fit on a s14 diff?
If not;
The rear hubs are also z32. Can we just use the s14 diff, s14 axles on the z32 rear hubs? Will it work?
I serched i promise
Originally Posted by yomisiu View Post
^ its OK. he's from Florida.
HIGHFIVEBETA is offline   Reply With Quote
Old 12-28-2012, 07:18 PM   #2
milesbizzell
milesbizzell's Avatar
milesbizzell is an unknown quantity at this point
Send a message via Yahoo to milesbizzell
If not;
I serched i promise
i know this may be late in the game but, i will tell you what i did.
i had a 1 wheel wonder from my original rear end s14 with the KA24DE engine.
After I swapped the KA for the SR, I bought a 300zx Z32 NA R200 diff.
I then took out my OEM shafts and put them in the R200 and left my axels also. so now i have pos traction and only replaced the pumpkin itself.
It has lasted 5 years no problem.
milesbizzell is offline   Reply With Quote
