Old 07-22-2020, 10:35 AM   #1
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
Drag Silvia S13 street car shoots for 9's
20200521_171446 by Fred Burge, on Flickr
IMG_20200718_101206_767 by Fred Burge, on Flickr
20200409_102618 by Fred Burge, on Flickr
20200228_182020 by Fred Burge, on Flickr
IMG_20200625_200515_727 by Fred Burge, on Flickr
IMG_20200716_122310_467 by Fred Burge, on Flickr
IMG_20200710_141728_613 by Fred Burge, on Flickr
20200718_102433 by Fred Burge, on Flickr
20200714_191558 by Fred Burge, on Flickr
Here's my 91 S13 that I've been working on for many years, it's finally to a point where I can get it out and have fun with it!
Silvia, built 5.3 turbo, 4l80e, [email protected]
Fred Allen Burge is offline   Reply With Quote
Old 09-25-2020, 08:48 PM   #2
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
Not sure why this was moderated, but it's finally approved.
Originally Posted by PHLIP
Old 09-26-2020, 06:46 AM   #3
tuzzio
tuzzio's Avatar
Seems like you have some dialing in to do. What trans?
Trapping 137 you should be in the 10.2/10.3 range.
Old 09-28-2020, 02:28 PM   #4
Fred Allen Burge
20200725_161635 by Fred Burge, on Flickr
20200928_151503 by Fred Burge, on Flickr
Made some progress at the track! I never even planned to run a 9, planned to run a 10 and that's as far as I figured I'd ever go but man she was running good and boom, [email protected]!
Unfortunately I also lifted a head and torched the gasket and the block and head so I had to tear it all apart to fix that.
20200726_171404 by Fred Burge, on Flickr
20200727_165120 by Fred Burge, on Flickr
20200726_175955 by Fred Burge, on Flickr
But now it's on head studs and LS9 oem gaskets and all back together. I also got told by track officials not to come back without a full cage so that really cut my racing season short lol. Now I gotta put a game plan together for a cage...but first I want some good street driving before it gets too cold for the year!
Very excited to run around on 700+ rwhp
Old 09-28-2020, 02:32 PM   #5
Fred Allen Burge
Built 4l80e with Circle D 3200rpm stall converter
Old 09-28-2020, 05:59 PM   #6
mrmephistopheles
Inactive Admin
Herdez is my favorite, btw.
Old 09-29-2020, 07:59 AM   #7
Fred Allen Burge
Current pic with new intercooler set up. Thinking about building a 1 piece cooling panel to cover up that whole area. Also after disassembling and painting my alternator it now won't charge doh! Guess I painted some areas that need to be grounded?
IMG_20200927_155635_988 by Fred Burge, on Flickr
Old 09-29-2020, 09:00 AM   #8
PoorMans180SX
PoorMans180SX's Avatar
Looks like a solid setup. Congrats on the Nines!
Old 10-02-2020, 08:22 PM   #9
Flicktitty
Flicktitty's Avatar
Awesome car man, i've enjoyed watching the build on IG.
Old 10-05-2020, 11:42 AM   #10
Fred Allen Burge
Thanks! @fredallenburge if anyone wants to connect on IG, I post up a lot more there and about my other cars too.
So, pulled alternator, stripped all paint off of all points that contact the block or the bracket, reassembled and still no charge. Had it tested at Autozone and it was just bad for who knows what reason. So warranty got me a new one and now that's all behind me.
But then...
The rear mains seal started puking VR1 all over the ground every time I fired her up - doh!
So Sunday I pulled the trans and replaced the seal and all's good again. 5 hours flat to pull trans, fix seal, eat lunch and reassemble everything - decent
Now it's finally time again to go to Mexico and log some hard pulls to see if my dual Walbro 450 fuel pump set up is working. Also to log IATs and see if this Bell Intercooler core is working. I had them spec it for 800hp at 20psi on a V8 but it's tiny - 16x8x3.5". Seems way too small but I spoke to the engineer guy there twice and he assured me that's the right size fore the job. I do need to build some ducting for it also so that it has the best chance possible of working so that's probably next up.
