Builds (and builds only) Got a build thread? It goes here, build threads anywhere else on the forum will be locked and never moved. |
05-31-2021, 04:45 PM | #61 |
Silvia's Helical diff is what I need in my life, haha.
I remember you writing on NRR about installing s15 helical and using Ford alternator bushings as a spacers for ring gear bolts. Would you share what model/year Ford alternator bushing were these? The Nismo conversion bolts I heard are discontinued now and rather expensive for what they are. What is your experience with these spacers, did they lasted without problems or are there other bolts from other cars that can be used instead of Nismos? |
06-07-2021, 01:28 AM | #62 | |
I have a few more in my toolbox so I just grabbed them. They are 12.03mm (0.4736") ID and 13.14mm (0.517") OD and 18.36mm long. After a bunch of digging around.. I think I may have discovered they are actually starter bushings. I found on Summit this bushing which is super close to what I have and should work: https://www.summitracing.com/parts/smp-x4349 I believe I also found the exact bushing I have as it's pretty much perfect match on all dimensions including length. It's a Delco starter bushing: https://qpselectric.com/en/bushings/4239-62-1400.html This diff lasted for quite a few years of street driving, drifting, and racing. It just recently came out of the race car to swap out gearing, so these bushings worked great. I have also heard of people not using any bushing, and just "preloading" the slack towards the acceleration side, but these bushings are cheap piece of mind. I just had to cut them shorter with a tubing cutter, so I actually got two from each one. |
06-07-2021, 05:12 PM | #63 | |
That's great seeing Randy driving your car! Super cool!
1990 240SX SR20DET GTX2863R |
06-08-2021, 07:58 PM | #64 |
Nice! Yeah Randy is amazing to get feedback from and tons of fun to have around.
06-23-2021, 07:20 AM | #65 | |
Sent from my HD1900 using Tapatalk |
07-11-2021, 11:46 PM | #66 |
No.. but thanks to your reminder I got started on editing tonight.
Tags |
240sx, endurance racing, race, vq30de |
