Old 05-23-2016, 02:42 PM   #1
Enjuku Racing
Enjuku Racing - Tomei Duracon Shift Knob 70mm
Tomei Shift Knob Short 70mm
Tomei began operations in 1968 as a race car tuner in Japan. Over the last 40 years Japan has emerged as one of the leaders in automotive research, racing, and culture. Tomei products have been utilized in nearly every motor sport imaginable. Tomei’s racing heritage means their research and design team have first hand knowledge of the extreme demands racing puts on an engine. Using only the highest quality materials means that Tomei’s products can handle the intense strain and heat a purpose built engine will experience whether it be on the street or the track. Tomei’s attention to detail is second to none. All of their products are thoroughly researched and engineered to achieve optimal efficiency. Because of even miniscule differences in measurements can cause catastrophic engine failure, all Tomei products fall within strict tolerances. Tomei machines all of their engine components to enhance airflow and ensure proper fitment and seal.
Tomei Duracon Shift Knob for compatible M10 x 1.25mm shifters. Made of Duracon, a material of Polyoxymethylene composities that is known for their high degree of crystallinity, and in turn offers high strength, stiffness and hardness, good chemical and environmental resistance including heat and moisture absorption. The shift knob is about no more than 5 ounces, so it is very lightweight and high strength.
Please Note: Shift knob only fits shifters with M10 x 1.25mm thread pitch (MOST MAZDA, MITSUBISHI, and NISSAN)
In Stock and Ready to Ship!
$26.95
http://www.enjukuracing.com
[email protected]
