For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
10-11-2016, 07:46 AM | #1 |
Sr20 greddy oil pan, bee*R rev limiter
I have a greddy oil pan for sale. No cracks or major damage. It has a few scrape marks on the bottom. Also someone stripped the drain plug hole but it was repaired and works properly now
$200 I also have a legit bee*R rev limiter ordered from RHDjapan. I did 1 lap with it and broke 2 rocker arms because I didn't listen to the Internet. NOT RECOMMENDED FOR USE ON SR. You've been warned. Otherwise it's in perfect condition. Comes with instructions, sticker, and electrical connectors that came with it. $200 Sent from my iPhone using Tapatalk |
10-19-2016, 06:22 AM | #8 |
no way that your SR just blew because the Limitter! Did you properly check how to set it up like gain wise? i put money you had the gain at the highest setting, to make the coolest flames, operators fault not the limitters, did you even read instructions? people tend to set these up and just wing it which is also a no-no.
10-19-2016, 06:31 AM | #9 |
these guys havent blown up, since you literally took it out for 1 lap and blew up i think it was another cause... im a Bee r distributor so i can tell you i know tons of sr cars with these and have no problems
10-19-2016, 09:18 AM | #10 |
I didn't blow the motor, it broke 2 rocker arms which everything I read said it would. I had the gain set low because I didn't want big flames of tons of obnoxious noises. I just wanted to keep the rpms at a proper range without having to pussy foot through the track. I did a ton of research on sr's with bee-r's installed and basically everyone said you'll break rocker arms and don't set the gain high. Rev limit was set to 7000 and gain was on 4 if I remember correct.
10-19-2016, 09:22 AM | #11 |
Also before you ask the head has poncams, tomei type A springs, and BC titanium retainers
12-20-2016, 06:32 AM | #16 |
Pm'd you. Let me know
