07-02-2008, 09:13 AM | #1 |
Enine won't fire up
Dohc Ka
My engine won't fire up, I checked battery/connection/starter/alternator/gas/sparks. What else do you guys recommend? It sounds like its out out of gas. Im lost... |
07-03-2008, 02:22 PM | #2 |
check car fuses?, put gas in the car too. but if u checked all the electrical and it seems proper. then move on to the power connection or signal to your fuel pump, lift up the rear covers and undo 4 nuts and one screw and see if the connector is still plugged in to the fuel pump if it isn't that... then move on and look into testing your fuel pump somehow
need more details though too... does the lights and ignition lights turn on when you turn key?? |
