Old 04-11-2008, 03:08 PM   #1
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
IACV Plug... What's actually needed?
So in my harness simplification process I've pretty much got everything figured out(I think), but am unsure about the IACV plug. It has four wires going into it.
I've come to the conclusion that I *should* only need two of these four. The light blue wire(signal) and the black/yellow wire(power). Am I right on this? The other two wires seem to be part of the AC. The other two wires are blue/green and blue/red.
Can anyone confirm?
TIA.
JVD is offline   Reply With Quote
Old 04-14-2008, 12:53 PM   #2
johngriff
johngriff's Avatar
johngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfection
Send a message via AIM to johngriff
From my understanding you only need the 2 wires + and - to pulse it on and off. The other wires list as going to the ac compressor, probably for a secondary position in the AAC when the A/C is switched on.
So if you are not using A/C then You could probably drop those.
[email protected]
johngriff is offline   Reply With Quote
