08-16-2011, 10:58 AM | #91 |
Before going off and buying a ls6 valley cover, I would recommend this route.
Get some fuel line. T-off rear valve cover fittings to the front going into a Norris Motorsports filter catch can, get a NEW style pcv valve from GM. (orifice type) then straight into your intake. DONE. had no oil going in at ALL. Or, you can take a different route, by venting your blowby gases. up to you, i chose the above route because I liked to run a catch can. Just make sure you get one that actually does its job and filters the vapor/oil. Of course theres guys who spend extra and get the ls6 valley cover, which is good/eliminates some hoses but unless you already have it. Its not really cost effective. Good luck |
08-16-2011, 02:01 PM | #92 | |
http://zilvia.net/advertise.html |
08-16-2011, 03:24 PM | #93 |
You sir are pure evil with this weekly update thing. Come on please don't make me wait like the guy in the Rb26 E30 did please!!!
Trade my Rb25 for some wheels. Buy my Sc300. |
08-17-2011, 09:53 PM | #97 | |
It basically took about 3 times as long as it should have, haha. Glad to hear you didn't have stupid problems with yours!
Instagram - SJKnoop |
08-17-2011, 10:00 PM | #98 |
Thought I saw the motor in the car when I went to UpRev a couple weeks ago? Build is coming along nicely though Edafe.
ShakotanOscar.blogspot.com |
08-17-2011, 11:23 PM | #99 | |
Thanks bro
Yeah motor is in the Z already, like I said before I am ahead of these build pics. Wanted to do it this way so everyone would not be waiting for parts to get here and updates on the build.. But I think I will catch up to where I am at now and then the waiting will start...lol But I will try and update every week.
08-21-2011, 05:52 PM | #100 |
Well got to this post early today, its a short one but its a good one... So enjoy:biggthumpup:
STAGE 1: Phase 4 'LS1 to LS6 PCV conversion' Okay this weeks beer of choice is New Belgium Brewing 'Lips of Faith Series' 'Super Cru'. This beer is pretty much a hopped up Fat Tire with double the malt and hops; Add in crisp Asian Pears, which is a Belgian thing to do; and bring it to life with a Saison yeast. With a ABV of 10% it does get the job done:JAMIN: Okay what we are installing today is a LS6 PCV system. You might be asking your self why do we need to change PCV systems. Well the reason we switched to a GM LS6 PCV system was to reduce oil consumption issues associated with the factory LS1PCV system. I got the kit from Thunder Racing, it includes everything needed to do the conversion: LS6 Valley Cover, valley cover gasket, valley cover bolts, LS6 PCV Tube, and valve cover plugs. Thunder Racing LS1 to LS6 PCV Conversion Kit : $169.99 This pic shows the difference in the to PCV systems. Bottom is the LS6 PCV system and the top is the factory LS1 PCV system. You can also see from this pic why some trimming is required. Start of by removing the old LS1 PCV system, I forgot to take pics of this stage, just thought it was straight forward enough. Next prep your area for cutting. Make sure you cover everything you can, use towels, blue painter tape every thing so no shavings get in the engine. Here is a better pic of the prep area taken from LS1Howto.com This is the piece that we are going to trim down. We need to chop the wall off this block all the way down so that its even with the bottom of the pit. It may help for you to mark a line on the aluminum about 3/4" down so you know where to cut Here is a better pic of the target area, pic taken once again from LS1howto.com Okay cut made. I just used my high power electric cutting wheel to cut this off. Another pic of the cut Once you done cutting the piece off make sure you clean the area very well before installing the new LS6 PCV system. The new unit should just drop right into place. Torque all 10 bolts to 18 lb/ft. Next, hand thread in both knock sensors until they bottom out. Torque these to 11 lb/ft. Reconnect both wiring plugs, and slide the plastic connectors back in place. Now there is more to the install but I have no need for it since I am going to route my PCV system to a Catch can later. So there you have it nice and quick and easy.. Total price so far: $4,240.19 Next week STAGE 1: Phase 5 'FAST 102 Intake/FAST 102 TB'
08-21-2011, 05:55 PM | #101 |
jelly of FAST stuff, nice work dude
www.stewartleask.com |
08-21-2011, 05:56 PM | #102 |
Also just wanted to say Thanks everyone for the kind words, its what keeps me motivated on this build.
So Thanks
08-21-2011, 07:30 PM | #104 |
Thanks bro, I am just trying to catch up to you.
08-24-2011, 01:43 PM | #108 |
Thanks everyone for the kind words..
Well to keep things going just wanted to share with you guys what I just picked up.. Got this sick I-Phone-4 case the other day by id America. Its a head gasket, pretty sick design I must say. The design of this case is by far well thought out. Has a lot of padding in the back to protect your phone.. Comes with these screen and back protectors.. I personally hate theses things so I did not install them.. They come in different colors like, gold, bronze and silver.. Bam there you have it..
08-24-2011, 02:17 PM | #110 |
08-24-2011, 03:34 PM | #111 |
man, sooooo wanted to get that cover in copper haha.
08-24-2011, 04:53 PM | #112 |
Trader Rating: (50)
Feedback Score: 50 reviews
awesome work man!
great build! hows your engine stand holding with that V8? it looks like its bending downwards from the weight. i had to buy that 1kg engine stand for my damn V8 rebuild.
"get that nacho out of my face" |
08-24-2011, 07:15 PM | #114 |
This build continues to be radical.
Continue with the good work. |
08-24-2011, 08:01 PM | #115 | ||
Yeah I almost got that one too, but wife said this one would pop better... They just released a rally blue.. looks rad.. Quote:
hahaha you know it Quote:
Thanks, and glad you like the beers
08-24-2011, 09:29 PM | #116 |
Liking the detailed nature of the thread - definitely in for seeing how this turns out! Keep those updates coming!
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
08-28-2011, 01:58 PM | #119 |
Okay beer of choice this week is Julius Echter 'Hefe Weisse' if you are looking for a good wheat beer then look no further.. I personally love hefeweizen type of beers and this one really hits the spot.. Hope you like. Okay what we have today to instill is a FAST 102 Intake with a FAST 102 TB, and a FAST fuel rail.. Now I bought this as a package deal on Texas Speed Shop, and yet again they do not disappoint. FAST 102 Intake/TB and Fuel rail kit from Texas Speed Shop: $1,653.98 (I added the Coolant pipes and plugs, fuel rail and gaskets) Man I just love how the FAST 102 TB is packaged.. I felt like James Bond opening up this case. Its well protected and overall just impressed me.. Now a lot of people might question the 102 Intake. Some say it does not give you any gains so why bother.. Well the main reason I bought this Intake was simply for my later plans for the motor. I do plan on storking this engine and running a twin turbo set up so this intake will def help me when I put down the big numbers. Got to plan ahead.. And damn does it just not scream beast mode...lol First thing to install is the new Coolant pipe for the front of the engine.. pretty straight forward here, you just place it where the old coolant pipes went. Next is the Coolant plugs for the rear of the engine... Place both coolant plugs where they are suppose to be, and tighten down.. Next is the FAST 102 Intake gaskets... love the orange Place around every runner... Next install the intake, follow the FAST instructions. They state what torque specs and proper order to torque down.. Next is the gasket for the FAST TB,, Place the gasket where it needs to be... And then install this beastly TB,, man this thing is nasty Almost complete.. Looks like an engine now.. Next is the FAST fuel rails.. Now I don't think I am going to keep these so if some one wants them shoot me a PM and I will sell them to you.. Going to go with the FAST Billet Fuels instead.. They come with spacers so you can run the factory LS1 injectors Sorry for the tilt of the motor in this pic but you get the idea... Engine is pretty much complete just have to install a few things but this is what it will look like.. Goodnight and sleep tight my lil engine.. Total price so far: $5,894.17 Next week STAGE 1: Phase 6 'Coils/Spark Plugs and Wires'
http://zilvia.net/advertise.html Last edited by Royal_T; 08-28-2011 at 06:54 PM.. |
