Old 08-26-2008, 06:17 PM   #1
neverrain
neverrain's Avatar
neverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud of
Ideas on a stripped bolt?
I'm having a PITA time getting the bolt on the hard line that runs from the clutch master cylinder to the clutch dampener loose. I've tried wrench, pliers, liquid wrench, wd40 and the bolt is stripping itself now. Anyone got any ideas of how i can get this bolt loose? It's the only bolt I can't seem to get off the dampener.
neverrain is offline   Reply With Quote
Old 08-26-2008, 06:22 PM   #2
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
vice grips
WangonwWarrior is offline   Reply With Quote
Old 08-26-2008, 06:25 PM   #3
WangonwWarrior
and if that does not work take the whole hard line and dampener out and lock the dampener down in a vice and get your vice grips out then go to town with some mad muscle
Old 08-26-2008, 06:27 PM   #4
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
vise grips and i think u need to flare/put a new fitting on
importdude is offline   Reply With Quote
Old 08-26-2008, 06:33 PM   #5
iluvpandas4
iluvpandas4's Avatar
iluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfectioniluvpandas4 is close to perfection
Send a message via AIM to iluvpandas4
Heat it up then go at it with a vise grip. Then of course, replace the bolt.
'92 240sx Coupe
iluvpandas4 is offline   Reply With Quote
Old 08-26-2008, 06:59 PM   #6
neverrain
neverrain's Avatar
Yea I disconnected the hard line from the master cylinder and pulled out the entire dampener. Put it in a vice, put the vice grips on it hard and the damn thing still wont rotate.
If I just cut the hose off will a new clutch line come with bolts on both sides? Also, I have the bolt from the other line that is perfect. Of course the one I needed to keep is the one that is giving me issues.
Old 08-26-2008, 07:18 PM   #7
neverrain
neverrain's Avatar
vice + vice grips worked eventually, +1 for reminding me.
Old 08-26-2008, 08:08 PM   #8
WangonwWarrior
hehe like i said go to town on that biotch lol
Old 08-26-2008, 10:37 PM   #9
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Use a flare nut wrench.
This is outside the scope of the question, but I recommend removing all stock hardline and flexline, including damper box. Install a braided line from the master straight to the slave and bypass the damper completely
g6civcx is offline   Reply With Quote
Old 08-26-2008, 10:57 PM   #10
WangonwWarrior
+1 i got one off ebay for $40, have not bled it yet though but i bet it will be firm
Old 08-26-2008, 11:49 PM   #11
neverrain
neverrain's Avatar
Yea I wanted to do this. This was actually my first time replacing anything related to the clutch so I read the hell out of everything I could find. I ended up removing the dampener, replacing the master and slave, and bleeding the system. This was a first for all of those. Now that I know what I'm doing (for the most part) I can go back in and replace the stock line with the braided one. The reason I didn't replace it today was because my master blew last night while I was at work and I had to take the day off to fix it. This car is a my DD and my only one.
Regardless, thanks for the help guys. I took the car out and the clutch feels nice and stiff now, though I'm not sure that's the result from removing the dampener or not.
EDIT - Also, I'm not sure the flare nut wrench would have worked unless you are thinking of one that might clamp down on the bolt. The bolt is literally so stripped now its round. I ended up having to use the vice grips to tighten it, which is another reason I need to grab the braided line, to replace that screw/bolt piece.
Old 08-26-2008, 11:58 PM   #12
g6civcx
g6civcx's Avatar
damper = something that dampens, i.e. reduce the effect
dampener = something that makes it damp, i.e. wet
Who knows why.
You should have started with a flare nut wrench. Once the bolt is rounded the flare nut wrench won't work.
Old 08-27-2008, 08:08 AM   #13
projectRDM
projectRDM's Avatar
projectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfectionprojectRDM is close to perfection
A new OE hardline is less than $14 at the dealer.
And FYI, the part you damaged is called a nut, not a bolt. I skimmed this over before because your post made no sense, there are no bolts fitted to a hardline anywhere.
FORMERLY R240NA
Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com
projectRDM is offline   Reply With Quote
