Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 02-13-2013, 03:13 PM   #1
nissannick
nissannick's Avatar
nissannick is an unknown quantity at this point
Post z31 help
So i have a 1988 300zx that i recently purchased and its an automatic. i also picked up every single part i need to do a 5 speed swap. The only thing im missing is the clutch line that goes from the master to the slave cylinder, im not sure where to find one or what i can use as a replacement. The only thing i found was a s13 clutch line(steel braided) and im unsure if that will thread up if anyone has any info please let me know thank you.
nissannick is offline   Reply With Quote
Old 02-14-2013, 01:30 PM   #2
adamvann3
adamvann3's Avatar
adamvann3 is an unknown quantity at this point
You can bend your own hardline, its not to complicated.
88ss 368
adamvann3 is offline   Reply With Quote
Old 02-14-2013, 02:06 PM   #3
nissannick
nissannick's Avatar
alright thats probably a good idea. does anyone know anyone that did a 5 speed swap in a z31?
Old 02-14-2013, 04:10 PM   #4
DeleriousZ
DeleriousZ's Avatar
DeleriousZ is an unknown quantity at this point
Send a message via MSN to DeleriousZ
This should get you on your way:
XenonZ31 Automatic to Manual Transmission Swap
z31 Lovin'
http://imageshack.us/a/img337/2396/lowerit.jpg
DeleriousZ is offline   Reply With Quote
Old 02-18-2013, 11:21 AM   #5
adamvann3
adamvann3's Avatar
I have done an auto to 5spd swap. Pretty straight forward. I was lucky enough to have a full parts car so it was pretty easy having all the parts available.
With that being said I have bent hard brakelines for vehicles in the past. Need a radius bending tool and something to flare.
88ss 368
Old 03-03-2013, 12:53 PM   #6
darth z
darth z is an unknown quantity at this point
Where can i find a vg30 na 5 speed trans??
darth z is offline   Reply With Quote
Old 03-04-2013, 09:06 AM   #7
nissannick
nissannick's Avatar
good stuff guys thanks for all the help. im getting started today with the 5 speed swap ill let you guys know how it goes
300zx, 5speed conversion, clutch, line, z31
