06-02-2014, 08:09 PM | #1 |
Idling Issue Unsolved .... Ka24de
I have yet to solve my Idling issue with my Ka24de and need some help. The car will be fine in park when cold (1000 rpm), but once it gets up to normal temperatures (700 rpm) and i begin to turn the steering left or right in park the idle drops pretty quick and starts to run rough then stalls. I have no CEL and I have changed my steering pressure switch, looked for leaks, cleaned out my IACV and egr Any help would be greatly appreciated
06-06-2014, 07:31 PM | #3 |
Have you tried pulling the power steering belt off and trying it? You could also try raising the front wheels off the ground (use jack stands if you can) and try it. These should remove the load being placed on the power steering pump.
Why are you turning the wheels sitting in park? |
