01-05-2017, 06:35 AM | #31 |
Trader Rating: (129)
Feedback Score: 129 reviews
holy FUCK. you can get a used maf here on zilvia for under $100
do some searching about 240sx with maf issues and see if the symptoms listed match yours. also, like snags said, if you had a bad maf, the check engine light would be on. did this mechanic say anything about the clutch or exhaust leak? |
01-05-2017, 10:07 AM | #32 | |
Jesus, take it to the local trades school for auto repair, they'll do a better diagnosis. Even if it was, that $600 is robbery!!
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
01-05-2017, 10:09 AM | #33 |
There has to be another member her that can recommend a competent shop or help you look at your issues near Hollyweed, CA.
01-05-2017, 10:14 AM | #34 | |
01-05-2017, 10:16 AM | #35 |
He's not charging me for anything just yet, he told me I could come by and take the car free of charge it's been at his shop since Monday. Btw the shop is Crown Auto Repair in Santa Monica.
01-05-2017, 10:41 AM | #36 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
before replacing your MAF... get a can of MAF cleaner for $8 from any auto parts store. Unscrew the 2 phillips head screws holding your actual sensor in place, unclip then unplug the MAF harness and carefully pull the sensor out, spray down the MAF sensor like crazy with the MAF cleaner. Wait 30 seconds to a minute for it to dry completely and reinstall! This will more than likely fix any and all MAF related issues.
01-06-2017, 11:12 AM | #37 | |
01-06-2017, 11:56 AM | #38 | |
Also maybe buy a Honda. |
01-09-2017, 08:44 PM | #39 |
Alright so I tried cleaning the original MAF with the cleaner and no luck. So I bought a new one from autozone $135 I don't think it's too bad. The car isn't as loud anymore and it doesn't sound like it has a exhaust leak either. But now there's a new issue where it struggling to get power, it's really sluggish but after I hit 3k RPM it feels normal. When I first turned on the car again is was back firing on idle. Any ideas?
01-14-2017, 04:45 PM | #41 |
Alright so I changed all Spark plugs they were all black but my car still feels sluggish right after every shift, I'm stuck on what it could be. Car just got a new Fuel Pump, new flywheel, new clutch and I changed the transmission. The previous owner of the car said the transmission was new so I decided to put it on since it was already off from changing the clutch. Could this be cause by my transmission?
01-16-2017, 10:55 AM | #43 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
same pump, just different sending unit setup.
KA24e pump works fine on a KA24de and vice versa. a difference of 10hp doesnt make a bit of difference. |
Tags |
clutch 5 speed swap, flywheels clutch s13, fuel pump, s13 240sx, trans s13 transmission |
