Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 03-07-2012, 12:16 PM   #181
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Happy Hump Day! Godspeed Project - Automotive - El Monte, CA | Facebook
Godspeed Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988
W:godspeedproject.com
www.facebook.com/godspeedproject
Fatboy Garage is offline   Reply With Quote
Old 03-13-2012, 10:55 AM   #182
Fatboy Garage
Happy Tuesday Bump! Check out our fan page!!! Godspeed Project - Automotive - El Monte, CA | Facebook
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 04-10-2012, 03:23 PM   #183
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
interested in 18g turbo for sr20 pick up price
PIN GIO 2 is offline   Reply With Quote
Old 04-21-2012, 03:05 AM   #184
bluekouki
bluekouki is an unknown quantity at this point
so i got th 20g up and running, very happy with turbo the only problem with it is the wastegate i think its a little weak , the boosts creeps up slowly to red line ,at red line i get full boost 20psi ....should i upgrade with hks wastegate?
bluekouki is offline   Reply With Quote
Old 04-23-2012, 07:28 PM   #185
Fatboy Garage
You could try to use an HKS wastegate but check to see if vacuum lines are free of any leaks and other things that can cause it to creep.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 07-10-2012, 06:58 PM   #186
Fatboy Garage
Bump for the week!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 07-12-2012, 10:05 AM   #187
GreenMNTDC5
GreenMNTDC5's Avatar
GreenMNTDC5 is an unknown quantity at this point
Originally Posted by Fatboy Garage View Post
If you have any questions regarding this turbo let me know! Check out the TD05-18g on a KA24DE!
KA24DET Chris Billedo @ Adams Motorsports Park. Drift - YouTube
What's it take to get this into a ka24de???
GreenMNTDC5 is offline   Reply With Quote
Old 08-15-2012, 11:04 PM   #188
redss
redss's Avatar
redss is making a name for him/her selfredss is making a name for him/her self
I am have a hard time trying to keep these turbos boosting anything less than 20PSI. Does the actuator work fresh out of the box or do I need to adjust it?
I have both 18G and 20G but I have a bad feeling that if I keep spinning them at 20+ psi, they are going to crater. Is there a maximum boost rating they can spin safely?
redss is offline   Reply With Quote
Old 08-16-2012, 11:06 AM   #189
Fatboy Garage
20psi is not the maximum. From personal testing we've gone up to 29/30psi. Try taking the "load" off the actuator by pulling the nut out. That should help it go back to the 14psi that it's rated at.
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 08-18-2012, 10:27 AM   #190
redss
redss's Avatar
Adjusting the actuator works. Awesome power at 19 to 20psi.
I posted a question to your PM about the 20G. Can you reply?
Old 09-09-2012, 12:06 AM   #191
600supersport
600supersport's Avatar
600supersport is an unknown quantity at this point
this 20g is lining up well with everything so far from my s15 t28 on s13 redtop in my '95 zenki, just need to change the oil feed fitting bolt, shave some off the motor mount and it's good to go, everything else fits.
600supersport is offline   Reply With Quote
Old 09-19-2012, 10:48 AM   #192
Fatboy Garage
bump for 20g!!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
