s13 Won't start after head gasket change
94 s13 KA24DE
Cams are in the same place as before, lobes on cyl. 1 (closest to rad) pointing opposite, TDC set, at second notch from the top of the crank pulley. Distributor set same as previous, which lined up similar to where it was before disassembling. SIMILAR isn't good enough, why wouldn't it line up? I tried all of the teeth, it will not line up exactly with cyl. no. 1's corresponding plug wire. Anyway, I played with the distributor timing a little bit, and I eventually got it to fire up! 200rpm, tons of misfires, rev'd to 3000 when i gave it some gas, then when i let go it shut right off. When I unplug the fuel pump fuse, it tries to start a little bit. Shortly after plugging it back in it doesn't even want to fire. I read all around the forums, others have had similar issues but nothing worked for me. Any ideas?? |
#2 | |
![]() Join Date: Jan 2012
Also are you sure you've tried all the teeth? It took me several tries to get my dizzy right, I kept stabbing it to the teeth on either side. Remember the dizzy rotates as it slides in. |
Okay, that makes sense that it floods when the timing is off.. because it's not starting and fuel is unburnt.. haha that solves that problem that I should have already known.
Now, when it did start, after I killed it (like as I was taking the key out..), it would still fire one last cylinder. Maybe I'll try to move the distributor up one instead. I thought it was two behind, so I tried moving it two that way. I'll try moving it up, then. Haven't tried that yet. Obviously my cams are in correctly, since my valves still work. lol |
#10 | |
STILL DIDNT FUCKING START!!! My friend suggested that my lower timing chain may have slipped a notch but I don't understand why that matters. the distributor is in the right place and so are the cams. what else prevents a car from starting.. I heard there is a kit you can buy??? |
#11 | |
![]() Join Date: Nov 2012
if the lower slipped a notch, the piston would be coming up a link too early, meaning the exhaust and intake are a notch too late or vice versa. yes it matters |
#12 | |
kit for what? lol |
