08-31-2005, 04:14 PM | #1 |
wiring problems near ecu
i'm having wiring problems i think...i got stuck finishing a sr20det swap into a 91 240 coup and i cant get it started. i have no spark. i thought it might be at the ecu where that white plug comes out of it. it has about 11 wires coming out of the ecu and snaps together with the stock 240 harness plug. then runs up along the underside of the fender on the passenger side.? Do i need to alter that plug, like you have to cut the plugs near the stock battery location so that the right wires meet up with eachother on those 3 harness plugs??Either cut them or alter them so you can still use the plugs. Thanks for any random info, I've been through it all with this shit. definitly worth it
08-31-2005, 06:13 PM | #2 |
You want to tell us what the fuck you're trying to do?
You don't need to alter anything to fix a problem, if you're swapping in another motor then yes, you do.
08-31-2005, 06:19 PM | #3 | |
08-31-2005, 08:37 PM | #4 |
For the white connector, use the following colored wires which, in most cases, match exactly between the KA and SR:
