Old 02-20-2014, 10:27 AM   #1
XAlliedYouthX
XAlliedYouthX is an unknown quantity at this point
SR20DET starting/running issue
So, my SR20DET swapped S13 was running fine about a month ago when I finally found a garage to store it but decided to crap out on me a few weeks later. I tried starting the car and it would just crank and crank while also having what sounds like a metal squeeking/screeching noise. After messing with it for a few days it finally started up last night. I didn't doing anything between the last time it wouldn't start and last night so I don't know what changed. Well when it was finally running it would start, stumble a little and then fall on it's face. I did this a few times and found that giving it gas would keep it going until I finally was able to start it and have it stay running.
My concern now is that when I rev the car it has the same screeching sound as it did when I was failing to start but does it on initial startup and on revs. Also, there was whitish gray smoke coming out of the exhaust. I didn't think to rev from the throttlebody so I'm not sure where in the motor the screeching is coming from.
Any help would be greatly appreciated.
XAlliedYouthX is offline   Reply With Quote
Old 07-14-2014, 10:43 AM   #2
Reveleven
Reveleven is an unknown quantity at this point
I am having a similar problem, although when I give mine any throttle it goes into what I feel is a limp mode and just bounces the RPM's. No throttle response, no power and won't idle and falls on it's face and dies. I'm stumped.
Reveleven is offline   Reply With Quote
Old 07-14-2014, 06:09 PM   #3
TurboTiger
TurboTiger is an unknown quantity at this point
Does is sound like a belt is loose when is screeches? Also, what does the smoke smell like?
TurboTiger is offline   Reply With Quote
Old 07-14-2014, 06:11 PM   #4
Reveleven
It fouls plugs and smells like fouled plugs. I guess I don't really know how to explain the screech. Is it when it's starting or about to die?
