Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 09-06-2008, 10:23 PM   #1
EAT Motorsports
EAT Motorsports's Avatar
EAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of light
Send a message via AIM to EAT Motorsports
All New HKS Turbo Timer
The All New HKS Turbo Timer
HKS USA, Inc., celebrating its 35th year as the premier manufacturer and supplier of automotive performance systems and parts, is proud to announce the ninth generation of the HKS Turbo Timer available for sale on September 10th, 2008.
In 1982 HKS introduced the world’s first Turbo Timer to assist in cooling down the turbocharger to prevent oil coking in the center bearing cartridge assembly. Oil "coking" occurs when a turbocharger is not properly cooled down and the oil that normally lubricates the center cartridge heats up and forms solidified oil deposits. A turbo timer allows an engine to idle for a preset amount of time after the ignition key has been turned to the off position and removed. By allowing a turbocharged engine to idle, oil continues to pass through the turbo until it has cooled down to the point where oil "coking" will not occur. Re-designed for 2008, the all new Turbo Timer Type-0 and Type-1 feature a new, slim low profile design with a separate LCD display and control unit following the same design concepts as the current HKS EVC and A/F Knock Amp.The Turbo Timer Type-0 features a red LCD backlit display for easy visibility, 2 timer modes, and a battery voltage meter with a peak value indication and warning function.
The Turbo Timer Type-1 features a light blue LCD backlit display and has the same basic timing and voltage features as the Type-0 plus several monitoring and measurement functions. The Turbo Timer Type-1 features an Auto mode for the timer function allowing the Turbo Timer to automatically calculate optimum idling time according to the most recent driving pattern. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A two-stage RPM warning can also be set and used as a shift indicator. When a warning level is reached the Type-1's LCD monitor will blink and an audible beep will sound. The HKS Turbo Timer Type-1 also features various measurement functions including 1/4 mile timer, 0-60 timer and a stopwatch function that can be used for lap timing. The Turbo-Timer Type-1 can read in either MPH/SAE or KPH/Metric.
The new HKS Turbo Timers are compatible with all HKS Turbo Timer harnesses to make for an easy installation.
  • MSRP: $155
  • Positive Lit LCD
    • Red Back Light
  • Black Display Case (W:89.5mm/H:22.5mm/D:13mm)
  • LCD Display (W:41.5mm/H:11mm)
  • Black Control Unit Case (W:69.0mm/H:80.0mm/D:21.0mm)
  • Timer Fun ctions:
    • Manual Mode (0-10 Minutes)
    • Memory Mode #1 (1 touch, 1 Minute Setting)
    • Memory Mode #2 (1 touch, 3 Minute Setting)
  • Battery Voltage Display:
    • Battery Voltage
    • Peak Value Indication
    • ON/OFF Warning Function
  • Compatible with all HKS Turbo Timer Harnesses
_______________________________________
Turbo Timer Type-1
  • MSRP: $155
  • Positive Lit LCD
    • Blue Back Light
  • Timer Functions:
    • Auto Mode (0-5 Minute Setting)
    • Battery Voltage
  • Vehicle Speed Indication Function:
    • Vehicle Speed
    • Peak Speed Hold Value
    • Speed Warning Function
  • Engine RPM Indication Function:
    • Engine RPM
    • Peak Engine RPM Hold Value
    • Engine RPM Warning Function
  • Display in either MPH/SAE or KPH/Metric
  • Metric Distance Time Functions:
    • Acceleration Distance (0-100m, 0-200m, 0-400m)
    • Section Time (200-400m)
    • Acceleration Time (0-100km/h, 100-150km/h)
    • Auto or Manual Start for Quarter Mile Function
  • SAE Distance Time Functions:
    • Acceleration Distance (0-60 foot, 0-1/8 mile, 0-1/4 mile)
  • Stopwatch Tool Time Measurement
    • Total Elapsed Time
    • Lap Times
Will ship next week!
Call, AIM, or PM any Questions
Call 1-866-451-2261
or
Thank you for your business and support!
Anthony
EAT Motorsports
Call 1-866-451-2261
AIM - EAT MotorsportsA
Email - [email protected]
EAT Motorsports is offline   Reply With Quote
Old 09-06-2008, 10:46 PM   #2
Z33dori
Z33dori's Avatar
dam.... i like..
looks like i finally found a TT for my car..
Old 09-06-2008, 10:56 PM   #3
mr_240sx
mr_240sx's Avatar
mr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfectionmr_240sx is close to perfection
Send a message via AIM to mr_240sx Send a message via MSN to mr_240sx
wow that seems to be a great turbo timer with a great price tag as well! im sure these will sell great! best of luck with them.
mr_240sx is offline   Reply With Quote
Old 09-07-2008, 03:06 PM   #4
s14sport
s14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura about
HKS Turbo Timer
Do you have the harness for 96 240sx?
s14sport is offline   Reply With Quote
Old 09-07-2008, 03:51 PM   #5
EAT Motorsports
Sure do. All Pms replied.
thanks
Old 09-07-2008, 03:55 PM   #6
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
lucky i held off on a timer. this one is nice, clean, and beautiful. ill take the type-1 for an s13.
chetacheese is offline   Reply With Quote
Old 09-07-2008, 04:38 PM   #7
surge s14
surge s14's Avatar
wow i haven't even though about a tt yet ill be getting one form you soon.
surge s14 is offline   Reply With Quote
Old 09-07-2008, 06:49 PM   #8
SR2Zero
SR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really niceSR2Zero is just really nice
These look badass. I'll be picking one up next paycheck.
SR2Zero is offline   Reply With Quote
Old 09-07-2008, 09:38 PM   #9
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Nice new product !! I'll add it to my wish list !!
WoolyS14DET is offline   Reply With Quote
Old 09-07-2008, 11:19 PM   #10
dannyk20
dannyk20 is an unknown quantity at this point
nice.......... i will be ordering the Type 1, next week for sure
dannyk20 is offline   Reply With Quote
Old 09-08-2008, 04:37 PM   #11
EAT Motorsports
Thanks guys! All PMs Replied, Let me know if you guys have anymore questions.
thanks
Old 09-09-2008, 01:46 PM   #12
blues14kouki
blues14kouki is an unknown quantity at this point
respond
please pm price for type-o to 95128. . .and also do you carry universal harnesses
blues14kouki is offline   Reply With Quote
Old 09-11-2008, 10:23 PM   #13
EAT Motorsports
All PM's Sent/ Replied
thanks
Old 09-19-2008, 10:56 AM   #14
EAT Motorsports
All Orders Shipped, Few left for this batch.
Old 09-19-2008, 08:55 PM   #15
OperationSr20
OperationSr20's Avatar
OperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond reputeOperationSr20 has a reputation beyond repute
I wish the Type-1 came in Red! But beggers can't be choosers; how long do you anticipate this price to stay?
SHIFT_Patience
1989 Ka24De Hatchback:
12/20/2005 - 11/03/2006
1991 Ka24De Hatchback: 12/20/2006 - Current Day
OperationSr20 is offline   Reply With Quote
Old 09-19-2008, 09:27 PM   #16
threats14
threats14 is making his/her stupidity well-knownthreats14 is making his/her stupidity well-knownthreats14 is making his/her stupidity well-known
type 1 sent to 96744 + HKS harness for an s14.
threats14 is offline   Reply With Quote
Old 09-19-2008, 11:56 PM   #17
UcanTry
UcanTry's Avatar
UcanTry is an unknown quantity at this point
Send a message via AIM to UcanTry
did you get any type 1 in? also need a s14/s15 harness
UcanTry is offline   Reply With Quote
Old 09-22-2008, 12:07 AM   #18
EAT Motorsports
PM's Sent, all orders shipped
thanks
Old 10-04-2008, 01:06 AM   #19
EAT Motorsports
Few Left, thanks for the orders! These things rock!
eat motorsports, hks, timer, turbo, turbo timer
