Old 07-10-2009, 01:59 PM   #1
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
wangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfectionwangan_cruiser is close to perfection
Feedback Score: 36 reviews
Send a message via AIM to wangan_cruiser
anoder sr swap fuel pump not working
i finished my swap and ready to fire her up.
but i cranked it didnt start.
then i checked the fuel lines first if im getting fuel. no pressure. no fuel when i pulled the hoses.
so i went back to the inside and turn the ign key on to listen if the fuel pump is priming. no response
double checked the harness i cut and splice located from the side of the battery.
i spliced them one by one carefully so i wont mixed things up.
then double checked the clip from the back where the fuel pump is connect for voltage and it has one.
now im stumped and dont know where to look.
anyone can help me?
wangan_cruiser is offline   Reply With Quote
Old 07-10-2009, 02:01 PM   #2
johngriff
johngriff's Avatar
johngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfectionjohngriff is close to perfection
Send a message via AIM to johngriff
ECCS relay circuit, or ecu.
[email protected]
johngriff is offline   Reply With Quote
Old 07-10-2009, 02:07 PM   #3
wangan_cruiser
kouki man
Trader Rating: (36)
i just checked the relay for voltage and pull ing 12 v
then i double checked the relay if its till good and it works.
then when i turn the ign key i double checked the ecu to see if it flashes.
no flash at all. it should flash the light right?
Old 07-10-2009, 02:10 PM   #4
johngriff
johngriff's Avatar
S13? Yes. Manually force the relay over by grounding the eccs pin, should force the fuel pump on.
[email protected]
Old 07-10-2009, 02:11 PM   #5
wangan_cruiser
kouki man
Trader Rating: (36)
cant tell which is the eccs pin.
ive doing my research since yesterday to figure out which lines and pin out.
Old 07-10-2009, 02:50 PM   #6
wangan_cruiser
kouki man
Trader Rating: (36)
bump anyone?
Old 07-10-2009, 11:51 PM   #7
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
On the S13 fuse box the EGI label is the relay for the ECU, and the EGI Pump is the relay for the fuel pump. If you're sure your relays are fine then it more than likely could be your ECU or an error in the harness job.
Just last month my ECU completely died on me. Initially I thought my fuel pump was toasted so I immediately bought another and installed it to no avail. I decided to pop in my friend's known working ECU and sure enough all my problems were solved. If you have a friend who will lend you a working ECU you can go from there.
Old 07-11-2009, 02:13 AM   #8
wangan_cruiser
kouki man
Trader Rating: (36)
i just fixed the issue just now.
thanks for johngriff and russ.
Old 07-11-2009, 10:43 PM   #9
StevenMFQiu
StevenMFQiu is an unknown quantity at this point
what was the problem and what did u do to fix it? i have a similiar problem right now
StevenMFQiu is offline   Reply With Quote
