![]() Join Date: Dec 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
FRSport Deal of the Day: Nismo RB20 RB25 Short Shifter
![]() ![]() FRSport Deal of the Day: Nismo RB20 RB25 Short Shifter Nismo 32839-RN580 Solid Short Shifter - Nissan Laurel/Cefiro/Skyline RB20DE/RB25DE The NISMO Solid Short Shifter for Nissan Laurels, Cefiros, and Skylines with RB20DE or RB25DE engines, is a drop-in application that effectively reduces the stroke by 10% between gears while also `solidly` engaging in gears. Nismo is the best for anything Nissan and is the top choice of all major Nissan tuners out there! NISMO uses a harder rubber compound in the inner part of the shifter to reduce deflection. This helps with overall shift feeling so you know when the car is in the exact gear. They also reduce the shift throw distance by 10%, to allow for slightly faster shifting. By hardening the inner rubber of a standard shift lever, the amount of deflection is decreased. At the same time, the lever length was reduced by about 7.5mm, providing a stroke 10% shorter. This changes the rather soft touch of a standard car to a much more precise, fast feeling. At the same time, while the goal is to change to a quicker shift, an overly short shift stroke will result in poor, heavy shifting. Unlike a quick shift, the lever ratio has not been changed, so the transmission synchro is not effected and a moderately faster degree of shifting is possible. Installation is easy because the solid shift has the same basic dimensions as a standard shift. Specs:
Deal of the Day: Nismo RB20 RB25 Short Shifter<--click here Available for $199.95 *price good while supplies last add to cart to receive discounted price* Thanks, FRSport Team AIM: FRSportsales Email: [email protected]
FRSport.com || 18050 Newhope Street, Fountain Valley, CA 92708 (Map link) Store Hours: Mon - Fri: 8:00 AM - 6:00 PM PST [email protected] | 800-321-4747 | 714-515-4001 ext 146 FRSport.com Open Box Clearance Items FRSport.com Weekly Specials |
