Closed Thread
Old 06-05-2011, 06:56 AM   #1
nismo91blk240sx
nismo91blk240sx's Avatar
nismo91blk240sx is an unknown quantity at this point
Turbo 240sx parts & built ka24de
Full Name-Jordan Ulrey
Location-Elkhart, IN
Email- [email protected]
Phone Number-(574)215-525zero
ALL prices include shipping EXCEPT for the engine and trans.. I will get pictures Monday since it's at a friends shop and he's out of town
Built ka24de - $2500
All machine work done by Baker Prototype in Elkhart, IN. Assembled by myself. Has total of about 30 mins of run time due to lack of a tune. I am not looking to part out the engine. I'm also NOT looking to ship the engine
HEAD
-Ported and polished w/ 3 angle valve job
-Jwt s1 cams
-cometic mls headgasket
-supertech valves seals (not installed)
-supertech dual valve springs and titanium retainers (not installed)
-jwt adjustable cam sprockets (not installed)
BLOCK
-bored .20 over and line honed
-polished and knife edged crankshaft*
-balanced rotating assembly
-arp head studs*
-supertech 89.5mm pistons (9:1 c/r)
-eagle rods
-clevite 77 main and rod bearings
-arp main studs*
-oil return tapped oil pan
-skull works oil block adapter
-rps street max pressure plate w/ act 6 puck sprung clutch disk
-fidanza lightweight flywheel
-stock transmission
-rerouted coolant lines
-4an oil feed line
Top mount t3 manifold w/ external wg hole - $100
Q45 tb - $50
Custom aluminum*intake manifold w/ q45 flange and vacuum ports - $450
One piece steel driveshaft for s13 - $100
S14 Ka koyo radiator w/ custom shroud and Taurus e-fan - $250
Pbm coolant surge tank - $80
Pbm hood risers - $25
Aluminum coolant overflow - $45
Precision sc6162sp ball bearing turbo - $700
Blitz 3 inch downpipe - $100
Custom 2 pc downpipe 4 bolt flange - $100
Greddy 60mm peak and hold boost gauge - $125
Greddy 60mm peak and hold water temp gauge - $125
Greddy 60mm peak and hold oil temp gauge (no sensor) - $50
Greddy 60mm peak and hold oil pressure gauge (no sensor) - $50
Innovate motorsports lc1 wideband w/ xd16 gauge - $200
Blitz dttx turbo timer - $80
Bosch 044 300lph inline fuel pump - $200
s13 cooling panel - $40
silicone radiator hoses - $50
braille no weight battery (21 lbs & 1380 pca) - $130
msd streetfire multi-spark ignition - $150
precision 600hp intercooler (31.5x8x3.5) - $200
ngk s14 spark plug wires - $100
kenwood kdc-mp342u cd player - $100
nismo91blk240sx is offline
Old 06-05-2011, 08:20 AM   #2
WholeGrainS13
WholeGrainS13 is an unknown quantity at this point
Interested in turbo manifold and aluminum coolant res when pics are up.
WholeGrainS13 is offline
Old 06-05-2011, 05:15 PM   #3
boosted-s14
boosted-s14 is an unknown quantity at this point
do 100 on the shifter and meet for delivery..kokomo here
95 240sx se project underway
boosted-s14 is offline
Old 06-05-2011, 05:52 PM   #4
ka-turbo
ka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-known
pictures and reciepts????......how do we know you know how to instal and it was installed right...some cred would be nice
ka-turbo is offline
Old 06-05-2011, 06:21 PM   #5
nismo91blk240sx
Meet where? I'm not looking to drive too far if I'm going to take $30 off the price
Old 06-05-2011, 06:55 PM   #6
nismo91blk240sx
I'll take pictures with the valve cover and oil pan off when I bring it home in the next couple of days but I'm not going to take head off to prove there are supertech 89.5mm pistons.
What receipts do you want to see? I can supply you with Mick Baker's number because he did all the machine work if that's what you're questioning. And his normal machine work yields 1500hp nitro methane funny cars so he must know what he's doing. As for my experience, I have been building my 240sx engines since I was in high school and this one was my 5th complete rebuild. But if you don't want it because i don't have enough "cred" for your satisfaction, I'll be happy to put the engine in my garage on an engine stand until I get another shell..
Old 06-06-2011, 06:53 AM   #7
nismo91blk240sx
A few pics are up and I'll get the rest today or tomorrow
Old 06-13-2011, 09:04 PM   #8
nismo91blk240sx
pics are finally up.. sorry for the delay
Closed Thread
