06-13-2012, 07:05 AM | #61 |
Sounds like you have the majority of it figured out! Good find on those front hubs too, GTR front axles might not work, BUT at least you have a cheaper alternative to GTR hubs and front suspension. That multi-link front suspension is crap, idk why Nissan decided to use it on everything, Z32, Q45, GTR, etc, IT'S CRAP!
I have a GTS-4 axle laying around at one time. . . I'm 99% sure it's missing the inner part that would bolt to the front diff flange tho, but maybe that would at least give you a direction to go with the front axles? Just trying to help. I can't wait to see videos of this thing when it's on the ground and driveable! |
06-16-2012, 12:08 AM | #63 |
you upgraded the pivot ball too, right?
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
06-18-2012, 06:39 PM | #64 |
the jdm stuff is going to be pricier just for the sake of being pricier. G35x and M35x both use a seperable atessa transfer case from the auto trans. Use g35x transfer case on vq manual trans with x front diff and axles. swap x front hubs onto your altima spindles and your spline count is golden. as far as oil pan is concerned, pull g35x pan, take measurements and have a halfway decent fab shop replicate the axle tunnel.
done and done. the g/m35x stuff is coming down since it isn't 2005 anymore. |
06-20-2012, 05:42 PM | #66 |
Sorry about the lack of posts lately. The s13 needed new brake lines, then I found out that the threads were stripped on one of the rear 300z calipers. Have several project cars and it spreads me thin time from time.
06-21-2012, 12:53 AM | #68 |
jus backin you up, my bro
the pivot ball you got is shorter than the original, yes?
06-24-2012, 06:52 PM | #69 |
Well life has been throwing me curve balls lately so haven't had much time to play. Fuel pump went out in the yellow boomerang (92 SR20DET). Me and my son put a little time in the Louisiana 100F 50-70% humidity to get the dash out. Have to pull the rest so we can start cutting, and cleaning and welding and painting....
06-24-2012, 06:56 PM | #70 |
06-24-2012, 11:54 PM | #71 |
ive heard only good things from the z32 community about fork upgrade, which lead me to buy the kit from z1
havent had the change to install it yet, because i have to drop the tranny, booooo. but when i was first in the market, i was confused about the 2 different chromoly balls available. the longer one is a direct swap for the stock ball (to be used with the stock fork,) and the shorter ball is to be used for the solid fork.
06-27-2012, 08:07 PM | #72 | |
06-28-2012, 04:39 AM | #73 |
Thanks for the lead on the clutch fork upgrade, I'll be using it on my RB25. I got my kit through Zspeed though because they have a chromoly pivot ball included.
Good luck on this build, I'll be watching.
S12 || KN13 || S13 || B16 |
06-28-2012, 06:21 AM | #74 | |
On thread: This project sounds bigtime, I hope it will be worth it |
07-05-2012, 09:10 PM | #77 |
Sorry for the delay. I have made some progress. These pictures are unedited and not pretty! I promise it will look a little better once my brother and I are finished.
I have reshaped the AC box to provide more clearance for the passenger side head. The piece that I am holding has been moved to the left as it interfered with reshaping the firewall. The lower hard lines rotated to fit into the new location. Initial Firewall cut (there have been more adjustments) There is enough clearance around the transfer case to be able to change the fluid without dropping the tranny. Floorpan cut and test fitting transmission. I might move the engine forward just a hair to get the shifter lined up perfectly however, the further back and lower the better for balance sake. GTR crossmember was supposed to ship today and hoping I can find some axles soon. Guys help a brother out as I am not having any luck finding them! |
07-05-2012, 09:38 PM | #78 |
A cool side note is that there is no interference with the seats so full adjustabilty is still there. The passenger side tranny mount did have to go as it interfered with the front output shaft. Plan is to use the subframe rail on the passenger side as a mounting point and cross over to the opposite side hitting the factory spots on the drivers side.
07-05-2012, 09:45 PM | #79 | |
07-10-2012, 02:35 PM | #82 |
This thing is gonna be awesome and it's a Louisiana project! I'll be following this! Keep up the hard work and don't give up on it my fellow louisianian...
07-11-2012, 11:58 AM | #83 |
Thanks man! Should be making more progress soon so I can post it up. Have a lead on axles so that will help tremendously as well....
07-12-2012, 12:14 PM | #86 |
loving this build! keep up the good work.
07-12-2012, 01:27 PM | #87 | |
This one has been eating my money lately. New brake MC is on its way. |
07-12-2012, 07:46 PM | #89 |
Tags |
450sx, awd |
