Old 10-17-2008, 10:19 AM   #1
moonshinekouki
moonshinekouki's Avatar
moonshinekouki is an unknown quantity at this point
very harsh idel wiht 840cc injectors
so i got my s14 with rb25det series one with:
aem ems
840cc
gt35
44mm waste gate
it made 501 whrp at 19 pounds.
now my issue is that regardless of cold/warm start i cant get it to idle unless i have to hold the gas peddle down for about a min then it will idle amazingly at 1100rpm thats pretty damn good for 840cc injectors.
any tips of what i should be checking out to see why its doing this?
also does anyone know why the aem if u go lock to lock with the steering wheel the car stalls out is it becuase the ps pump goes on and off?
thanks for hte help in advance.
mikey
moonshinekouki is offline   Reply With Quote
Old 10-17-2008, 11:00 AM   #2
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
did you tune it for the 840cc injectors?
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 10-17-2008, 11:17 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
The better question is what brand injectors are they? Some injectors idle better than some. I got some Sard 850s on my SR w/ PFC and they idle like i got stock 370s in there...
CLICK HERE!!!
Old 10-18-2008, 11:58 PM   #4
moonshinekouki
yeah ther etuend for 840ccs
but my tuner called aem and even they said taht regardless of what brand injecotrs its hard to get 840ccs to idle properly with the aem.
there detchworths
Old 10-19-2008, 04:24 AM   #5
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
This is another issue I have with the AEM unit.
Haltech totally trumps the AEM in every respect when it comes to simplifying the break down of injector set ups. You can actually control the actual injector voltage, wheer the AEM just has pre-set injector settings which may not be a perfect fit in reality.
Sounds like an issue with wiring or possibly some sort of flaw in your AEM unit or the setup of your Idle configurations in the idle maps (again over complicatingf it)>
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 10-20-2008, 10:34 AM   #6
moonshinekouki
thanks steve
u seem like the go to dude for tuning on zilvia
ill try and trace the wiring and hope its not the aem.
Old 10-20-2008, 10:53 AM   #7
Darius
Darius is on the path to ruinDarius is on the path to ruinDarius is on the path to ruin
Your tuner doesn't know what he's talking about. Did you change the injector lag settings for the larger injectors? Deatchwerks has a spreadsheet for their injector latencies, and it lists what you should set them for in your EMS.
I don't see 840cc's listed. Are they purple side feeds? Did you have upgraded injectors before these?
Darius is offline   Reply With Quote
Old 10-20-2008, 11:30 AM   #8
moonshinekouki
nope i had stock injectors before with stock ecu.
