12-18-2012, 10:44 AM | #124 | |
Trader Rating: (79)
Feedback Score: 79 reviews
They go for $50-$100 just look around
My Build: The "Coupe De Ville" 1JZ Build!! |
12-18-2012, 10:51 AM | #126 | |
Trader Rating: (79)
& I was reading up on Advantages/Disadvantages of a Low Temp Thermo & I feel it will be an advantage on what my plans are for my vehicle
12-23-2012, 11:11 PM | #128 |
Trader Rating: (79)
Thanks hopefully after the Holidays things should pick up.... Working part-time, trying to get things in order to go back to school & making miracles for Christmas has been kicking my ass!
My Build: The "Coupe De Ville" 1JZ Build!! Last edited by jdm2191; 12-24-2012 at 02:34 PM.. |
12-24-2012, 04:24 PM | #129 |
Trader Rating: (79)
CHRISTMAS EVE UPDATE!
Nothing to major on this update just some small stuff... When I bought my 1J it had a broken PCV valve, so I picked up a Metal 2JZ PCV Valve & Grommet from Driftmotion. An since its a Metal 2JZ PCV its a 1000x better then the cheap Plastic 1J one & also my 1JZ is a Second Generation so it doesnt have the PCV problem that the First Generation 1J's have but definitely recommend this on any First or Second Gen 1J's to get rid of the Crappy Plastic ones... Also decided to ditch my original Z32 2+0 E-Brake Cables & go with the more commonly used Z32 2+2 Cables that I picked up from my buddy Roger & Eric (Driven08) along with his Custom Z32 to S13 E-Brake Brackets there TOP FLIGHT quality & would recommend them to anyone! Thanks again Roger & Eric! Forgot to mention I sold my old DD S13 Hatch about a month ago & Picked up a 89 X8 Cressida Ive wanted a Cressida/4 Door for a few years just wasnt ready for one but since then I've learned a bit about X-Chassis & have owned like 3 S13's I felt it was time....It's pretty cool car besides the monsterous stock ride height, Blown Struts, Blown Steering Rack, Ugly Blue Interior & the passenger side that was side swipped by the previous owner But besides that that Its runs well It has a rebuilt 7M (Fixed HG), AC & Heater...so thats good for me for now Im hopping it doesnt turn into a money pit but some money will eventually get put into it I cant help myself... Only things Ive done is.... -Lowered it on Stock S14 Springs -Swap out the Banged up Passenger Doors for Undented ones -Took off Monster Truck Mudflaps -Removed Lower molding under Doors Planning on.... -Getting New Struts -Rebuild Steering Rack -Tint -Slowly Convert the Interior to GRAY! -NEW RADIO! I dont own any Tapes! Then it will be a legit Daily in my Eyes... Height Comparision next to my Buddy Evan's X7 On Stock S14 Springs & Removed Mudflaps & Lower Molding FLANTING THE COLORS... #CLUBAUDACIOUS
My Build: The "Coupe De Ville" 1JZ Build!! Last edited by jdm2191; 02-08-2013 at 11:36 PM.. |
01-01-2013, 05:01 PM | #131 |
Trader Rating: (79)
Thanks I actually just finshed the clear coat ill have a update soon!
01-22-2013, 02:21 PM | #132 |
Trader Rating: (79)
UpDaTe.........!!!!
Well about time for a DAMN UPDATE! since I cut my Water neck I needed a RB/KA style Radiator so I picked up a USED Mishimoto Aluminum KA Radiator in good shape for a Superb Deal! I bent some fins back & Polished it up a bit to make look a bit better, but overall I feel it should keep the 1J cool til I get the Radiator I really want.... Oh & BTW I finally Dropped the beast into its home It was actually a pretty smooth drop with the TECH2 CROSSMEMBER/BRACKETS, IT WAS DEAD ON! Along with the XCESSIVE URETHANE MOUNTS everything was SLIDING IN LIKE BUTTER how it should be! I had to loosen the SWAY BAR because the oil pan was hitting it but i'm going to eventually order a SIKKY Sway Bar anyways... & SORRY FOR THE SHITTY PICS The shifter was close to NOT fitting , but it just made it! Would recommend a 3IN Extension mine is about 2 1/4......I threw it into gear a few times & its not hitting anything so im Happy. & THATS ALL FOR NOW FOLKS STAY TUNED FOR MORE! So my List of things left to get it running is... -Xcessive Trans Mount -Chase Bays Clutch Line -Fans/Shroud -PBM Intercooler -Fuel Pump -Downpipe/Cat-Back -XRP Lines for my PBM Oil Filter Relocation Kit -Sikky Sway Bar -Finish Wiring
01-22-2013, 02:30 PM | #133 |
Damn dude I'm really looking forward to this!!
Your car is definitely gonna be a beast, can't wait to see this thing running! Definitely can see the time, work, and motivation in this......definitely an inspiration. |
01-22-2013, 04:23 PM | #134 |
Trader Rating: (79)
Thanks bro so am I! Im glad someone notices the work I put into her, I know it could be alot better, but been having alot Family Issues & im currently Moving so its been tough to have time & money to work on her. This April will be 2 Years for the build & im getting Anxious!
01-22-2013, 06:31 PM | #137 | |
Even though you say that it can be better, you're actually still going through with it and not giving up on the whole build and that's what matters even if it's taken you 2 years to build, it will eventually be finish and it will be all worth it when you start eating V8s lol. Don't give up! Be patient and finish this thing! |
01-22-2013, 08:04 PM | #138 |
So sick man
I have joined this forum to see just this kind of build! I am doing a stock 1jz s chassis missile build. I had now learned a bunch from you and flicks threads. Thanks a lot guys for your hard work and in depth build post. It's answered a lot of Q's I've had. Hince the one or two post haha. I'm down in Murrieta and may have some questions man if you don't mind... build is coming out classy! Lol
01-23-2013, 09:26 AM | #139 |
good progress man, just get an isis conversion clutch line, it works perfect and its inexpensive.
also i dont know how true this is but i have 2 of my friends that run 1jz swaps and said that those DM crank pulleys are not good for the engine. If anyone can comment on this that wold be great. |
01-23-2013, 09:44 AM | #140 |
damn, your bay is looking awesome, is it silver or misty blue? I gotta say, the valve cover matches perfectly and looks oh so smooth.
thelittlebigblock.blogspot.com |
01-23-2013, 04:11 PM | #141 | ||||
Trader Rating: (79)
Thanks bro, I have some questions about Precision Turbos too when I eventually go single
Yeah I cant wait Quote:
01-23-2013, 11:59 PM | #142 |
Ill second the aluminum crank pulleys, i dont believe its that they fail, its that they dont do what the stock dampener does, dampen things haha. Im hoping mine holds out untill i can get an ati or fluid damper
01-24-2013, 01:44 AM | #143 |
Trader Rating: (79)
Im not worrying about to much, if it was a part alot of people were complaining about I wouldnt of bought it, but eventually the plan is to go with a Titan, ATI or Ross Dampened Crank Pulley
01-30-2013, 12:59 PM | #144 |
Trader Rating: (79)
UPDATE:
NOTHING MAJOR WITH THIS UPDATE JUST A FEW PARTS I PICKED UP/INSTALLED I FINALLY GOT AROUND & BOUGHT A MANUAL BRAKE PEDAL. I DROVE WITH A CUT AUTO ONE FOR SO LONG I THOUGHT IT WAS ABOUT TO HAVE THE PROPER PEDAL INSTALLED THIS DAMN THING FINALLY, MY Z32 BMC I SLAPPED ON MY CHASE BAYS PS LINE....CAME OUT REAL CLEAN MY BUDDY EVAN THAT WORKS AT TOYOTA HOOKED ME UP WITH SOME EXTRA COIL PACK COVER BOLTS HE DIDNT NEED...ACTUALLY MADE IT LOOK ALOT BETTER HAD TO DRIVE 2 HOURS TO BUY THIS DRIFTMOTION DOWNPIPE FOR DIRT CHEAP! BUT IT WAS WORTH IT, NO MAJOR DENTS OR HOLES. IT LOOKS OLD & NEEDS GASKETS BUT IT WILL DO THE JOB! THREW ON MY CRUSTY ASS HOOD THAT BEEN SITTING IN MY BACK YARD FOR OVER A YEAR! SINCE IM MOVING I HAD TO SLAP ALL THE BODY PARTS BACK ON THE CAR, UNTIL IM DONE MOVING STAY TUNED FOR MOREEE!
02-02-2013, 12:41 AM | #146 |
Trader Rating: (79)
On everything like Exterior, Interior, Swap, ETC? Or just the swap?
02-05-2013, 12:12 PM | #149 | |
Trader Rating: (79)
roughly...$4500 probably a little more...note alot of those parts I got were awesome deals! If it was retail it would probably be over $7k+
