Old 12-01-2009, 06:37 PM   #1
SMM
Trader Rating: (26)
SMM is an unknown quantity at this point
Feedback Score: 26 reviews
Are s14 and s13 inner and outer tie rods the same
Are the inner and outer tie rods from s13 the same as s14?
SMM is offline   Reply With Quote
Old 12-01-2009, 07:17 PM   #2
HPballer76
HPballer76's Avatar
HPballer76 is an unknown quantity at this point
i think they are a little bit different but im pretty sure they will work on either chassis.
someone correct me if im wrong.
HPballer76 is offline   Reply With Quote
Old 12-01-2009, 07:21 PM   #3
240sxxs
240sxxs's Avatar
240sxxs is an unknown quantity at this point
no innner tie rod for s14 is diff then s13
The pretty one Arn't free and the free one Arn't pretty
240sxxs is offline   Reply With Quote
Old 12-01-2009, 08:50 PM   #4
Sileighty_85
Sileighty_85's Avatar
S14 inner tie rods are thicker. The outer's ball joint is the same but where the rod threads into are bigger for the S14
so you CANT mix ball joints and rods
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
