Old 05-08-2010, 02:24 PM   #1
benc
benc is an unknown quantity at this point
Installing kouki tails
Hey,
i've tried searching but couldn't find a good answer
anyways, i'm thinking about buying a set of 180sx kouki tails for the s13
now it comes with the 2 tails and center piece. but not the lower piece under the tails.
now im wondering is it absolutely necessary to have the lower piece? or will the stock one work?
let me know!
thanks in advance
benc is offline   Reply With Quote
Old 05-08-2010, 02:28 PM   #2
SHINCHU
SHINCHU's Avatar
SHINCHU is an unknown quantity at this point
that depends.
do you want it to look like shit? then yeah it will work. (might need to cut a bit)
if you want it to look nice then you need it.
the way i see things: if its different, its for a reason.
kouki lights have more of a rounded slope down to the bottom of the lights form the center garnish.
zenki/chuki lights is a straight diagonal line.
look at some pics.
SHINCHU is offline   Reply With Quote
Old 05-08-2010, 02:38 PM   #3
benc
Just wondering if anyone has some pics with them installed using the stock bottom piece.
i'm getting a good price compared to what i've been seeing online for the tails, so i'm just wondering if they're worth my time
Old 05-09-2010, 12:53 AM   #4
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Originally Posted by SHINCHU View Post
that depends.
look at some pics.
Unless you're speaking from experience, I wouldn't say things like that.
No, you do not need to "cut a bit" at all.
No, it doesn't line up 100%, but it still works.
Here's how "shitty" it looks.
Honestly, if you're not too picky, it's not that big of a deal.
-Jspec-
Instagram/CrimsonRockett
Old 05-09-2010, 12:57 AM   #5
Teddy
Teddy's Avatar
Trader Rating: (44)
Teddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfectionTeddy is close to perfection
Feedback Score: 44 reviews
Just make sure you have the non-sunroof model S13. If your S13 has a sunroof then your taillights won't fit.
www.realize-jp.net
Teddy is offline   Reply With Quote
Old 05-09-2010, 05:49 AM   #6
slim_240
slim_240 is an unknown quantity at this point
just curious, but what difference is there between a sunroof and a non-sunroof s13?
slim_240 is offline   Reply With Quote
Old 05-09-2010, 06:02 AM   #7
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
one has a sunroof and the other doesnt
Old 05-09-2010, 11:38 AM   #8
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
I can't tell the difference. Is the 180 piece raised up flushed with the lenses?
g6civcx is offline   Reply With Quote
Old 05-09-2010, 12:26 PM   #9
Sileighty_85
Sileighty_85's Avatar
The lower metal garnish is thinner on the Zenki-Chuki lights
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-09-2010, 02:03 PM   #10
slim_240
thanks you da bomb
Old 05-09-2010, 04:06 PM   #11
Mister.E
Mister.E's Avatar
Trader Rating: (53)
thanks you da bomb
you're welcome
Old 05-09-2010, 05:12 PM   #12
CrimsonRockett
The Architect.
As said above, stock 240sx lower panels are thinner.
180sx panels stick out further, sit flush with the center garnish, and line up perfectly.
-Jspec-
Old 05-09-2010, 06:53 PM   #13
g6civcx
g6civcx's Avatar
Thanks.
I personally wouldn't give a crap for such a small difference. S13s probably have 100 other issues that need fixing before this.
Old 05-09-2010, 07:49 PM   #14
Mister.E
Mister.E's Avatar
Trader Rating: (53)
so true.
i didn't know that there was a difference between the non-kouki panels on the 180SX and the 240SX. Why did they even bother to make such a small change with the thickness? they should have just left it alone.
Old 05-09-2010, 08:07 PM   #15
benc
thanks for the responses,
anyways, what's the diff between sunroof vs non sunroof?
Old 05-09-2010, 08:35 PM   #16
Sileighty_85
I think he was joking At least i hope he was.
Tail lights will fit on any FB S13 chasssis.
I have them on my S13 and it has a sunroof
後輪駆動車1番
1986 SR86 - 200ish
Old 05-09-2010, 09:11 PM   #17
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
LMFAO!
