Closed Thread
Old 07-18-2008, 12:31 PM   #1
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
180sx Part out!! lots of jdm goods!! 180sx, sr20det parts and jdm aftermarket
****LIST UPDATED!
180sx spun a bearing, so Im parting out. heres the list of goods, prices will be up later. please pm with offers only if serious in purchasing the items. sick and tired of people wasting my time.
stuff sold:
-t25
-chuki turns sigs
-greddy boost gauge
-starter
-wiring harness
-tranny harness
-t3/t4 manifold
-apexi intake
motor brackets
oil dip stick and tube
motor/trans divider plate.
ka to sr rad hose
180sx side markers
cat
external wastegate
injectors/rail
cas cover
coilpacks
180sx brakes
cas
knock meter
1. FMIC w/ piping, couplers and bov.....$275 shipped
pics of it installed here: http://img154.imageshack.us/img154/5585/180sx001xe3.jpg , http://img154.imageshack.us/img154/7014/180sx002vh5.jpg , http://img118.imageshack.us/img118/2626/180sx003im9.jpg , http://img154.imageshack.us/img154/6694/180sx006kv3.jpg , http://img154.imageshack.us/img154/3317/180sx007qv4.jpg , http://img233.imageshack.us/img233/1620/180sx008yv4.jpg
3. S13 GAB Shocks w/ RSR springs....$350 shipped very rare, dampening is 6 way adjustable and rsr are the lowest springs I ever seen, way lower then any other lowering springs on the market.
more pics: http://img233.imageshack.us/img233/6448/180sx010nd3.jpg , http://img118.imageshack.us/img118/6392/180sx011gb6.jpg , http://img233.imageshack.us/img233/8222/180sx012ot1.jpg
4. sr20det oem clutch fan...$40 shipped best/most reliable cooling method in my opinion.
7. s13 sr20det maf....$80 shipped very mint
8. oem sr20det rubber intake pipe.....$35 shipped
11. s13 sr20det redtop 62 ecu.....$150 shipped
12. R32 GTR seats.......$450 + shipping seats are a little worn, cat not included
15. custom turbo elbow made for t4 turbo top mounted, bolts up to turbo then oem dp...$40 shipped
16. oem sr20det boost solenoid....$20 shipped allows you to run 10 psi when its hooked up
17. sr20det radiator.....$100 shipped no bent fins, mint
18. S13 Digital Climate Control, complete with all sensors/harness's.....$150 shipped
19. sr20det ignitor.....$75 shipped
25. Turbo Timer w/ s13 harness.....$50 shipped plug and play, no idea what brand it is.
26. HKS EVC 3 Boost Controller....$200 shipped comes with everything needed to install, mint condition
30. *Brand new* HKS style air filter w/ maf adapter......$45 shipped brand new, never used hks style mushroom filter and alum adapter.
31. sr20det alternator with all brackets....$130 shipped
33. Redtop Valve cover....$70 shipped
34. sr20det stock exhaust manifold...$40 shipped
35. sr20 oem used pressure plate + clutch.....$55 shipped
36. S14 SR t28 turbo lines...$35 shipped (minus 1 coolant line, comes with all neded bolts/fittings, not shown in pic)
38. cusco brake master cylinder stopper.....$60 shipped
39. S13 5 Speed ABS driveshaft.....$120 shipped
40. SR20DET power steering pump & brackets....$100 shipped comes with everything need to install the pump, brakcets, adjustment screw,etc
41. F1 RACING sr20det stage 3 clutch kit....$90 shipped
more pics: http://img227.imageshack.us/img227/7...0sx4003cf6.jpg , http://img146.imageshack.us/img146/2...0sx4004jm6.jpg
42. Circuit Sport Subframe Collars.....$70 shipped
43. sr20det a/c compressor, belt and brackets....$70 shipped
44. 180sx/s13 tranny mount & crossmember.....$60 shipped
45. sr20det water pump...mint......$50 shipped
46. 180sx rear calipers, pads(lots of life) and lines....$70 shipped
47. 180sx Gauge cluster, 41k........$50 shipped.
48. b&m shift knob $20 shipped
49. razo shift knob....$20 shipped
50. SSR Radiator Cap...$25 shipped
51. Empi tie rod boot....$20 shipped Brand new in box
52. 300zx front PBR Brake Pads......$50 shipped Brand new in box
53. 180sx 6 bolt VLSD w/ axles....$275 shipped mint condition with only 100k
54. sr20det redtop head....$175 shipped complete with cams, lifters, etc..
55. sr20det redtop block... not sure about price yet spun a bearing and blew a piston ring. comes with all internals.
56. sr20det stock intake manifold....$80 shipped comes with the gaskets
57. sr20det throttle body....$60 shipped
58. sr20det TPS....$60 shipped
59. sr20det redtop Idle Air Control Valve...$60 shipped
60. sr20det oem flywheel....$60 shipped resurface reccomended
61. sr20det knock sensor....$25 shipped
62. battery relocation kit....$70 shipped comes with metal mount, bungy cord, and plenty of 0 gauge wire.
njd07 is offline
Old 07-18-2008, 01:50 PM   #2
MartyMartyMarty
MartyMartyMarty is an unknown quantity at this point
Send a message via AIM to MartyMartyMarty Send a message via Yahoo to MartyMartyMarty
PM'd..........
MartyMartyMarty is offline
Old 07-18-2008, 02:20 PM   #3
yunk_s14
yunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud ofyunk_s14 has much to be proud of
pmed about those side markers
yunk_s14 is offline
Old 07-18-2008, 02:22 PM   #4
Okinawandrifter87
Okinawandrifter87's Avatar
Pm sent msglength
Driftphreak87
Okinawandrifter87 is offline
Old 07-18-2008, 02:37 PM   #5
penco
penco is an unknown quantity at this point
Pm sent about intercooler piping
penco is offline
Old 07-18-2008, 05:03 PM   #6
lordofthemiasma
lordofthemiasma is making a name for him/her selflordofthemiasma is making a name for him/her selflordofthemiasma is making a name for him/her self
prices ftw........
lordofthemiasma is offline
Old 07-18-2008, 05:12 PM   #7
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
let me know about my side markers
any MT seatbelts??? if so let me know
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
DALAZ_68 is offline
Old 07-18-2008, 05:42 PM   #8
njd07
njd07's Avatar
first one to send me $40 gets the side markers shipped. only has left side mt seatbelt.
njd07 is offline
Old 07-18-2008, 05:43 PM   #9
njd07
njd07's Avatar
Originally Posted by lordofthemiasma View Post
prices ftw........
pricing coming soon..very busy.
njd07 is offline
Old 07-18-2008, 06:35 PM   #10
nrmskate
nrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enoughnrmskate will become famous soon enough
Im interested in the FMIC, no BOV.
How much shipped to 62629?
PLEASE PM ME.
nrmskate is offline
Old 07-18-2008, 06:45 PM   #11
adrians_s13
adrians_s13's Avatar
I'd like a shipped quote to 90807 for the fmic pleeeeese
@adrianfromthecastle
adrians_s13 is offline
Old 07-18-2008, 10:28 PM   #12
Ninjabread
Ninjabread's Avatar
Ninjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfectionNinjabread is close to perfection
Send a message via AIM to Ninjabread Send a message via MSN to Ninjabread
All parts are legit, seller is legit
I saw everything myself, and I got the apexi megaphone off this car
613DriftWerks.ca
Ninjabread is offline
Old 07-19-2008, 12:58 AM   #13
BoroDrifter
BoroDrifter's Avatar
BoroDrifter is making his/her stupidity well-knownBoroDrifter is making his/her stupidity well-knownBoroDrifter is making his/her stupidity well-knownBoroDrifter is making his/her stupidity well-known
Send a message via AIM to BoroDrifter Send a message via MSN to BoroDrifter
what do you want for that t25? mileage? leaks?
BoroDrifter is offline
Old 07-19-2008, 01:04 AM   #14
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
are there any prices for these items or is it best offer?
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline
Old 07-19-2008, 01:46 AM   #15
dloong82
dloong82 is an unknown quantity at this point
price on the shock/springs shipped to 89084
dloong82 is offline
Old 07-19-2008, 05:41 AM   #16
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
price on the filter shipped to 12747?
burnsauto is offline
Old 07-19-2008, 07:27 AM   #17
tallman24
tallman24 is a well-known jackass
price
price on the shocks 33068.
tallman24 is offline
Old 07-19-2008, 10:02 AM   #18
dorkjoey240
dorkjoey240's Avatar
dorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nicedorkjoey240 is just really nice
Send a message via AIM to dorkjoey240
got any pixs S13 GAB Shocks w/ RSR springs on your car? bump
dorkjoey240 is offline
Old 07-19-2008, 11:59 AM   #19
1SicS13
1SicS13 is an unknown quantity at this point
price on injectors and seats please
1SicS13 is offline
Old 07-19-2008, 12:08 PM   #20
Ninjabread
Ninjabread's Avatar
Just to let you guys know, I THINK he's gone camping for the weekend, but he'll be back soon!
613DriftWerks.ca
Old 07-19-2008, 12:23 PM   #21
nrmskate
Okay, Dibs on FMIC.
PM me when you get back.
nrmskate is offline
Old 07-19-2008, 01:42 PM   #22
305_hustler
305_hustler is an unknown quantity at this point
Dibs on the Apex filter
305_hustler is offline
Old 07-19-2008, 01:48 PM   #23
burnsauto
burnsauto's Avatar
i think not, scroll up.
...i love this whole "dibs" shit, lol
Old 07-19-2008, 02:12 PM   #24
heiyuu
heiyuu's Avatar
heiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfection
Hey I am interested in:
intercooler + bov & pipes
rad
shipped to winnipeg mb, r2l 0a7
heiyuu is offline
Old 07-19-2008, 03:07 PM   #25
nrmskate
rad
Hey bub, I already called dibs on it.
Its all mine!
nrmskate is offline
Old 07-19-2008, 10:40 PM   #26
Import_Prophetz
Import_Prophetz's Avatar
Import_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura about
Price on turbo shipped to 80021
Import_Prophetz is offline
Old 07-20-2008, 12:57 AM   #27
battlescar
battlescar is an unknown quantity at this point
pmed about the shocks
battlescar is offline
Old 07-20-2008, 03:28 AM   #28
Nacho_240
Nacho_240's Avatar
Trader Rating: (36)
Nacho_240 is an unknown quantity at this point
Feedback Score: 36 reviews
Is this all you're parting out? If the car has a VLSD, I'll definitely take the halfshafts if they're 6 bolt OR axles if they're 5 bolt. LMK. I have money ready.
Nacho_240 is offline
Old 07-20-2008, 04:31 AM   #29
blacktop2nr
blacktop2nr's Avatar
blacktop2nr is an unknown quantity at this point
Damn I totally wanted the cat.... but since I cant have the cat, how much for the pass seat?
blacktop2nr is offline
Old 07-20-2008, 04:32 AM   #30
blacktop2nr
shipped to 85018 ?
Closed Thread
