Old 05-14-2005, 02:24 PM   #1
s134
s134 is a well-known jackass
HELP! need ka24de valve cover bolt tighting pattern!!! searched away no luck
does anybody have a diagram or something showing what order to tighten the bolts on the valve cover??!!!
s134 is offline   Reply With Quote
Old 05-14-2005, 02:39 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Dont worry about it that much. Just do a star type pattern, everyother dealy. Dont strip it out man
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 05-14-2005, 02:54 PM   #3
s134
16lbs right?
Old 05-14-2005, 06:58 PM   #4
Yurand
Yurand is an unknown quantity at this point
I don't think there is an exact torque specified in the FSM. Definitely don't overdo it or you'll strip the threads in the head.
Yurand is offline   Reply With Quote
Old 05-14-2005, 10:16 PM   #5
s134
you da man
Old 05-15-2005, 09:23 PM   #6
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
16 lbs!! NONO!! Here's a link to a post I just made.
http://www.zilvia.net/f/showthread.php?t=80064
If you've torqued the bolts to 16 ft/lbs loosen them and retorque them per the diagram and at 6-8 ft/lbs
Also the previous diagram shows 12 bolts???? WTF? My 91 and my 96 only have 11 bolts. hmmmm.....
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 05-15-2005, 09:49 PM   #7
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
it shows 11 bolts. you're supposed to tighten the first one then retighten it again when you've done all the others.
papershot is offline   Reply With Quote
Old 05-16-2005, 02:16 PM   #8
Dream240
Dream240's Avatar
Why re-tighten it? If you've got it tightened down to say 8 ft/lbs then it's done. Putting the torque wrench on there to snap it tight again only tightens it further. Trust me if you try it you will see the bolt turn a little more with every click of that wrench. One bolt = one click = done.
Where did you get that diagram anyway? hmmm.....
Old 05-16-2005, 08:44 PM   #9
s134
i tqed em down to 8
no leaks !!
Old 05-17-2005, 02:39 PM   #10
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
wow never knew u needed instructions to tighten a valve cover... must be really hard...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-17-2005, 06:11 PM   #11
Dream240
Dream240's Avatar
ha, ha...not hard you just need the basic info to do the job right!
Old 05-20-2005, 07:41 PM   #12
s1d3ways
s1d3ways is an unknown quantity at this point
Send a message via AIM to s1d3ways
haha , all i needed was tighting patter lil bud
s1d3ways is offline   Reply With Quote
Old 05-20-2005, 08:26 PM   #13
S14DB
AFC #1
S14DB's Avatar
8lbs=finger tight
Old 05-21-2005, 02:35 PM   #14
Dream240
Dream240's Avatar
Originally Posted by S14DB
8lbs=finger tight
yeah if you're spiderman.
Old 05-21-2005, 03:03 PM   #15
S14DB
AFC #1
S14DB's Avatar
using a 12" wrench and pulling with all 4 fingers...
Old 05-21-2005, 05:16 PM   #16
Dream240
Dream240's Avatar
Yeah i know i was joking.... it's hand tightening not finger tightening. And I think a 12 inch wrench would be overkill... it's 12mm.
Just being anal.
Old 05-21-2005, 07:01 PM   #17
S14DB
AFC #1
S14DB's Avatar
The wrench not the socket.
Hand tight is using your whole arm.
Old 05-23-2005, 08:55 AM   #18
s134
job done like 2 weeks ago!
