Old 11-30-2013, 04:06 PM   #1
mojo9430
mojo9430 is an unknown quantity at this point
s13 Starting issue...
Hi... I have a 1990 240sx, manual trans. When I go to start it it cranks slow then clicks. Battery is charged, checked for parasitic draw (none), starter checked out and is good. I can turn the starter over fine if I put a jumper on the ignition wire (the thin wire on the starter) and connect it to the positive terminal on the battery. Once I hook the thin wire back up normally it does the slow crank again. Could it be the ignition switch itself, or the clutch safety switch? Thanks...
mojo9430 is offline   Reply With Quote
Old 12-01-2013, 09:06 PM   #2
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Try another battery in the car.
