For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() 1992 Nissan 240sx Coupe S13 Silvia includes the following:
ENGINE & DRIVETRAIN SR20DET Blacktop long block includes:Wiseco Pistons, ACL Bearings, ARP Head studs, HKS head gasket,and trans-1500 GReddy Intake Manifold(real not fake I have paper work and GReddy sticker)-500 70mm Pulsar Throttle body (water fittings and other idle things machined off)-500 GReddy Oil Cooler (mounted but never plumbed up or used)-500 Nismo Motor mounts & Tranny mount-150 GReddy Type-R Intercooler (1 pipe modified to fit top mount but have pipe for stock intake mani)-450 GReddy Upper Intercooler pipe (modified for TiAL BOV)-75 HKS F-con V-Pro 3.3 (Newest version with harness and sensors)-1500 Agency Power Stainless Steel Braided Clutch line-30 Nismo Pro 2-Way Rear Differential in a rear-800 CHASSIS & SUSPENSION Peak Performance 5-Lug Front & Rear Hubs (Front has their nicer kit with extended studs, made of Chromoly)-600 INTERIOR Key!s Suede Steering Wheel-250 Momo Wheel Hub-30 Yashio Factory Shift Boot-b/o BRIDE Upholstered Rear Seat-400 BRIDE Upholstered Glove Box-300 Brand New Black Carpet (not installed with trunk)-150 Omori 60mm Boost Gauge-50 ALL OTHER NISSAN & 240sx RELATED PARTS ENGINES & DRIVETRAINS S13 SR20DET Redtop Head-100 S13 SR20DET Blacktop Head-100 Built S13 SR20DET Blacktop Head (worked on by Head Games & Mazworx w/ machined quench areas, Manley 1mm over stainless steel valves, Tomei solid lifters, Tomei Rocker Arm Stoppers, Tomei Cam Gears, SuperTech Dual Valve Springs, Titanium Retainers, drilled out for ½” Head studs) S13 SR20DET Blacktop Block (w/ Darton Sleeves pressed in & machined to 87mm, CP Pistons 87mm-Brand New in Box, Manley TurboTuff Rods, ARP ½” Head Studs, ARP Main studs, New Water pump, New Oil pump, New Timing chain & New guides, New Gaskets) Kelford 274/278 Int./Exh. Cams (Brand New in Box) S13 SR20DET Valve cover, Shaved, -10AN fittings for breathers OSGiken 3-speed Set – New in Box-1300 OSGiken Input Shaft-goes with gear kit S14 Manual 5-speed Transmission-250 S13 SR20DET Transmission (disassembled)-b/o INTERIOR & EXTERIOR JDM Gauge Cluster w/ 9000rpm Tachometer(the clear cover part isnt mint, I gues u need that head light restore stuff-60 Key!s Suede Shift Knob-b/o MISCELLANEOUS S13 SR20DET Stock Intake Manifolds (4 or 5 available)-b/o DIF Dual Fan Controller-50 Yashio Factory Radiator Cooling Panel-200 A few Starters-b/o A few Alternators-b/o Several Brackets-ask S13 A/C Condenser-b/o KA24DE A/C Compressor-b/o SR20DET A/C Compressor-b/o Bell Housing Plates-b/o Fuse Box Covers-they're not mint anymore but if you dont have one Radiator Overflow Bottle stock-b/o Stock Glove Box-b/o Goodridge Rear Stainless Steel Braided Brake Lines – New in Box-b/o Pair of 5-Bolt Axles-b/o Brass Bushings for Door Hinges – New in Box-40 Shift Boot Ring-b/o Stock Shift Boot-20 Megan Sub-frame Bushings – Never installed-b/o GReddy Downpipe (cut in half but I can TIG it back together)b/o AEM oil press gauge brand new in box-b/o Last edited by nissan240sxkid; 04-22-2011 at 06:45 AM.. Reason: remove parts |
![]() Join Date: Sep 2009
![]() Feedback Score: 22 reviews
Was there a typo on the glove box/rear seats? haha
Also, sweet engine bay! I think we actually have the exact same color engine bays lol! Black base, rainbow flake? this is mine: ![]() |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
wow, we are both selling almost the exact same sr hah good luck with your sale...mines taking forever hah
https://instagram.com/eck_matthew/ |
#30 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() Feedback Score: 23 reviews
Do you have pics of the JIC Toe Arms and the Kazama control links???
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87 |
Tags |
greddy, hks, part out s13 sr built, sr20, wiesco |
