Old 04-28-2010, 01:50 AM   #1
85turbo_s12
85turbo_s12 is an unknown quantity at this point
1996 240sx will not start
A buddy and myself have just completed a ring and valve seal job on a 1996 s14 auto trans and the car will not start it has fuel it has spark timing is on target per the fsm everything is on spec all sensors and plugs are hooked up but it will not fire, and we have no idea why my buddy seems to think it's low compression because the rings havent had a chance to seat but it doesn't sound like low comp to me. It cranks hard but will not fire like something is missing. Any help will be greatly appreciated and there is somewhat of an urgency to this matter because the owner of the car needs the car back asap so the quicker the response the better thanks
85turbo_s12 is offline   Reply With Quote
Old 05-01-2010, 08:50 PM   #2
R_G
R_G's Avatar
R_G is an unknown quantity at this point
well check compression and valve lash.
R_G is offline   Reply With Quote
Old 05-02-2010, 04:47 PM   #3
buentellomma
buentellomma's Avatar
buentellomma is an unknown quantity at this point
have you checked all your wires to see if maybe some got cut or melted? i would start with a volt meter at the coil and work my way back until you find where its not getting fire.
buentellomma is offline   Reply With Quote
