Old 03-02-2015, 02:35 PM   #1
supasan
supasan is an unknown quantity at this point
S13 front caliper rubbing rotor
Hi I have a 92 s13 with stock brakes all around. Just recently I heard a scraping noise coming from the passenger front brakes. When I went to check it out. I found out that the caliper was missing a bolt causing it to run against the rotor making a ring around the top of the rotor. I replaced it with new bolts and pins, torqued everything and it's still rubbing! It was happening intermittently now it seemed to have gotten worse.
-new caliper bolts and pins
-pads are like new
-rotors never been replaced but doesn't look warped
-checked wheel bearing play. Has little to no play
Any help or advice would be greatly appreciated. Thank you in advance. I'll post pics later
supasan is offline   Reply With Quote
Old 03-03-2015, 08:04 AM   #2
supasan
Anyone? I swapped rotors with the driver side but it's still happening on the passenger side.
