Old 04-19-2016, 06:53 PM   #1
GumbyS13
GumbyS13 is an unknown quantity at this point
Sr wont run with MAF plugged in.
So i recently did swapped a S13 red top into my s13, everything works properly but it wont run with the Maf plugged in. It wont even start. When unplugged it itll start fine and run great (obviously in limp mode) but the minute the connector touches the plug the car dies. Now i have 2 known working maf sensors (ones from a single cam ka, and ones a z32) and i have a brand new Wiring Specialties pro harness, and have tried 3 different ecus. ...same problem. I have triple checked for Boost/vacuum leaks and have found nothing. I can even put my hand over the intake while the car is running and itll choke out the car and itll die. Im at a complete loss here and cannot for the life of me figure this out. Any help or input would be GREATLY appreciated.
Sent from my SM-N920P using Tapatalk
GumbyS13 is offline   Reply With Quote
Old 04-19-2016, 07:00 PM   #2
Lil_D
Lil_D is an unknown quantity at this point
your maf might not be getting power check the wiring at the ecu and trace it to the maf plug
@lild415
Lil_D is offline   Reply With Quote
Old 04-19-2016, 07:13 PM   #3
GumbyS13
Ill double check, but last time i checked all the wiring checked out at the plug.
Old 04-20-2016, 04:55 PM   #4
GumbyS13
So i got 12v to the power wire, however my signal wire is getting .002 volts any reason why?
Old 04-20-2016, 07:22 PM   #5
keaning
keaning is an unknown quantity at this point
The 4 pin connector goes like this
A. No pin
B. 12v
C. Negative
D. Signal
If you have power and ground, then pull the sensor out and clean it, otherwise try a different maf because z32 is completely different and probably won't run good at all
keaning is offline   Reply With Quote
Old 12-15-2016, 05:45 PM   #6
89'sil40coupe
89'sil40coupe's Avatar
89'sil40coupe is an unknown quantity at this point
any updates man? just got my redtop in my s13 and it starts and runs fine with the maf unplugged but as soon as i plug it in it starts idling really weird and eventually dies. car has a brand new wiring specialties pro harness. any help would be appreciated
93' sr sil-40
89'sil40coupe is offline   Reply With Quote
Old 12-15-2016, 05:48 PM   #7
keaning
I'd try cleaning the maf and if that doesn't help try a different one, it might be bad
