Old 04-30-2010, 04:44 PM   #31
Wake
Wake's Avatar
Originally Posted by waffel View Post
(bump)
holy shit thats cool thnx
i just wish i had the color my friggen cigarette lighter thing wont work and i need it for GPS =/
Are you talking about the orange and black wires that run to the bottom of the lighter assembly?
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 05-01-2010, 01:40 AM   #32
TerminalSamurai
TerminalSamurai is an unknown quantity at this point
Send a message via AIM to TerminalSamurai
Am I blind, I could have sworn there was a relay diagram layout (driver side) for the single cam in the FSM....
TerminalSamurai is offline   Reply With Quote
Old 03-31-2011, 07:27 AM   #33
bb4_96
bb4_96 is an unknown quantity at this point
Sorry to bring this back from the dead but I'm pretty sure the '89 FSM does have pinouts of all the connectors on the car, albeit the wire colors aren't always 100%.
bb4_96 is offline   Reply With Quote
Old 10-07-2011, 08:25 AM   #34
coupster
coupster's Avatar
coupster is an unknown quantity at this point
I have an odd question, I bought a 93 S13 (coupe) front clip and I am using the wire harness that came with the clip. My issue is that the harness is cut where they made the cut for the front clip as seen in the picture attached. Would it be safe to assume that the wires on my 93 240s coupe are an even one for one swap?
coupster is offline   Reply With Quote
Old 11-20-2011, 08:44 PM   #35
Saint1899
Saint1899 is an unknown quantity at this point
s13
yes Jordan that is a damn good idea, but all the info the op posted is readily avail in chiltons and FSM's.
but if you need any help with that Jordan let me know because I have 2 S13's worth of wiring harnesses, and I mean complete uncut harnesses so if you need to know the wire colors coming or going from anything Im sure I can help.
Seriously let me know.
Hi how are you sorry to bother you but i'm trying to figure out why my instrument cluster does not work. I have a 89 240sx that i just swapped out the SOHC with the DOHC i was wondering if you had the Pinout for the Body Harness that hooks from the computer to the Dash.
Saint1899 is offline   Reply With Quote
Old 11-20-2011, 09:59 PM   #36
bataangpinoy
this is fucking dope.
Old 08-13-2012, 10:16 PM   #37
DrFaust
DrFaust is an unknown quantity at this point
Ive just about finished an rb20det - s13 conversion with a bare and basic s13 body harness and and rb engine loom.
This doco helped me find those pesky two wire i need to link to the speedo sender to get it running. - Ive spent a year looking online for info haha.
Now just to get my tacho working and my dash clock to show some numbers on it.. any ideas ? lol
DrFaust is offline   Reply With Quote
Old 08-13-2012, 11:22 PM   #38
GSXRJJordan
GSXRJJordan's Avatar
Dash clock will come on with power and ground to the cluster. Tach wire is a single wire straight from the tach to the engine speed output on the ECU, and use the potentiometer to match what you see on the needle to what you see with a timing light.
Old 08-13-2012, 11:56 PM   #39
DrFaust
Sweet thanks. My clock lights up, but just doesn't show any numbers, will there be a seperate wire for this, or is the clock real basic and not connected to the ecu to keep the time? I do keep the battery disconnected as the car s not road legal yet I connect it when I'm ready to try fire it up or test radio wiring etc
Old 11-19-2012, 12:56 PM   #40
bataangpinoy
this is very useful.
Old 12-20-2012, 03:22 PM   #41
2LiterTurbo
2LiterTurbo's Avatar
2LiterTurbo is an unknown quantity at this point
This is VERY helpful!!
2LiterTurbo is offline   Reply With Quote
Old 02-03-2013, 02:46 PM   #42
mikevskater
mikevskater is an unknown quantity at this point
On the EFI harness, where would I find a new F-28 and F-29 Resistor/Condenser. Both of mine are fried. Can I go to the Nissan dealer and have them bring up this harness then get a part number?
mikevskater is offline   Reply With Quote
Old 02-07-2013, 11:21 PM   #43
kawitwofiddy
kawitwofiddy's Avatar
kawitwofiddy is an unknown quantity at this point
hey ive got a quick question on the body harness. There is one thick black ground wire going through the entire harness. I have the connection to ground it on the passengers side dashboard frame, but i follow it back towards the fuse block and smj, and its cut about a foot away from the fuse block. I cant figure out if i cut it or if it was just like that(cant imagine it being that way) does it just ground to the frame on both ends of the thick black wire?
kawitwofiddy is offline   Reply With Quote
Old 02-20-2013, 01:28 PM   #44
1slowM6
1slowM6 is an unknown quantity at this point
Is all this the same as a 1993?
1slowM6 is offline   Reply With Quote
Old 03-09-2013, 12:15 PM   #45
sked707
sked707's Avatar
sked707 is an unknown quantity at this point
Good info here thanks for posting this & bump for you!
sked707 is offline   Reply With Quote
Old 03-05-2014, 07:04 PM   #46
Mike40
Mike40 is an unknown quantity at this point
does anybody know how to de-pin the wires on connector E203 on the lower engine harness, its the one with the teal center on the face of the plug,
Mike40 is offline   Reply With Quote
Old 03-05-2014, 07:09 PM   #47
Mike40
does anybody know how to de-pin E202 connector on the lower harness, its the one with the teal stip on hte face of the plug, goes to fues box harness...
Old 03-05-2014, 07:13 PM   #48
Mike40
lol though i posted on different page, but E202 is the connector im looking for information on de-pinning
Old 03-10-2014, 12:47 AM   #49
jkfdhklfchil
jkfdhklfchil is an unknown quantity at this point
I've never had a problem with mitchell???
jkfdhklfchil is offline   Reply With Quote
Old 06-02-2015, 12:38 AM   #50
Skellis14
Skellis14's Avatar
Skellis14 is an unknown quantity at this point
is it hard to build your own wire harness?, i if pulled all of the relays and fuses one by one and slowly rebuild it to length would that change the values of the fuses or relays?
Skellis14 is offline   Reply With Quote
Old 06-17-2015, 07:59 PM   #51
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
holy crap. I haven't been on zilvia for some time now, I'm really glad this has been viewed so many times and helped people along the way. I really need to get that pin-out scanned up for everyone. I'll see where that damn book went to.
burnsauto is offline   Reply With Quote
Old 06-22-2015, 07:48 AM   #52
Tucker240
Guest
Posts: n/a
--Deleted--
Old 07-30-2015, 11:01 PM   #53
Skellis14
Skellis14's Avatar
colors colors colors colors
Old 01-01-2016, 10:53 PM   #54
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
is there an s14 equivalent? or is it practically the same?
DJTTon is offline   Reply With Quote
Old 11-13-2016, 08:38 PM   #55
ogs13
ogs13's Avatar
ogs13 is an unknown quantity at this point
Colors soon please, In a mess with wiring my 240. Currently trying to wire my brake lights.
ogs13 is offline   Reply With Quote
Old 11-14-2016, 10:31 PM   #56
soundbwoy
soundbwoy is an unknown quantity at this point
thank you!!
soundbwoy is offline   Reply With Quote
Old 07-11-2017, 09:47 AM   #57
Shirohige
Shirohige is an unknown quantity at this point
Anyone still have these? Or know where I could find them?
Shirohige is offline   Reply With Quote
Old 03-20-2020, 04:27 PM   #58
Kaiba
Kaiba's Avatar
Kaiba is an unknown quantity at this point
Yo, Photobucket fucked this extremely valuable resource. Can we get these images re-hosted or can someone supply the images to make a replacement thread please?
LOOKING FOR: S13: Power Doors! Hit me up!
Kaiba is offline   Reply With Quote
Old 03-20-2020, 05:03 PM   #59
JDM240z
JDM240z's Avatar
JDM240z is an unknown quantity at this point
I have a S13 DOHC master wiring book. Lmk what you may need and I can post some.
JDM240z is offline   Reply With Quote
Old 03-23-2020, 07:40 AM   #60
crash n' burn
crash n' burn's Avatar
crash n' burn is on a distinguished road
JFC just let this thread stay dead. This was no more than pictures of the FSM which can be found online in multiple places.
@jz_2tone
crash n' burn is offline   Reply With Quote
diagram, wiring, wiring body harness s13
