03 rhd forester $14k
selling my 03 forester, its been rhd converted using a ver 7 sti front clip, the perfect daily driver,with cold a/c. looking to get $14k obo .The outside is subaru desert khaki paint easily paint matched for touch ups. the paint could use some touching up too, 5 years of being daily driven took a toll on the hood and rear wheel arches, but easily fixable cant find the dyno sheet but 2 years ago it made around 498hp/410tq on rt tunings dyno. text me or email me any questions- (732)-407-3221 keith.
heres the spec sheet: 2003 subaru forester vin:jf1sg63643g701746 odo: 118k engine- 2.5 darton sleeved heat treated crank manly h-tuff rods je pistons acl bearings arp l19 headstuds heads had intake and exhaust ports cleaned and smoothed bc intake valves bc iconel exhaust vavles new valve seals bc stainless springs bc ti retainers bc 272 cams bc adjustable cam gears gates racing belt phenolic intake spacers intake manifold port matches to tgv deletes garrett gen 1 stock location gt35r turbosmart 44mm wastegate tomei header unequal legnth snow performance stand alone meth kit cobb ap v3 cobb boost controller synapse bov perrin fuel rails perrin aos cusco mounts Drivetrain: 04 sti 6 speed clutch masters twin disk nitraded coated syncros dccd controller driveshaft shop rear 1000hp conversion axels Brakes/wheels: work tr7 wheels 18x9.5 +35 new michellin pilot super sports almost new 04 sti brembos front dba rotors pmu pads new rear rotors new pads 5mm extended studs stainless lines Suspension: feal 441+ coilovers with swift springs whiteline sways bars whiteline mounts whiteline sway bar links whiteline anti lift kit ver7 sti front controll arms ver7 sti quick steering rack interior: tanabe revel gauges pioneer double din all the jdm bits recaro sr5 seats jersey red planted seat rails wrx rear seats grip royal steering wheel nrg quick release splash adaptor hub (only one that keeps the signal cancel) pros: turn key daily car started life as a base forester 2.5x so, low insurance about 500hp rhd fun to drive and comfortable has remote start perfect for anything cons: paints chipped rear wheel arches are a little rusty turbo oil drain is seaping a bit seats might be too low for you ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by shift0246; 01-25-2021 at 09:28 AM.. Reason: price change |
True , but unlike the 03 jdm foresters that you still can’t legally import , this one has a us title where all you need to do is go to the dmv and register it no problem , plus it also has a Impreza dash instead of the ugly forester ones . Motor, trans , and turbo stuff alone add up to about 15k
#19 |
why would you throw so much money at a rust bucket? And then rice it up on top of that? You know how this game works, you're not getting your money back.
swap all the parts to a clean shell, you'll have a better chance then.
Tuners are big bullies ![]() |
#20 |
03 rhd forester $20k
yeah, im on it ^ anything else I should fix that you don’t like ?
Last edited by shift0246; 07-30-2019 at 03:05 PM.. Reason: Needed to be more sarcastic |
Tags |
daily driver, rhd, subaru |
