Old 06-19-2013, 09:16 PM   #1
Toplevel4ever
Toplevel4ever's Avatar
Toplevel4ever is an unknown quantity at this point
1996 ka24de into 1990 (1996 harness)
EDIT
Forget it. getting 91-93 parts lol
So I just purchased a 1990 240sx with a 1996 ka24de swapped into it but unfinished. It's 1996 everything. Engine, trans, engine harness and ecu. Has anyone done this using the 1996 harness and all?? I need help with what wires I need hooked up to get it running.
All the guy had done was had the engine and trans installed and that'd it. I've had it cracking but no start yet. I hard wires the fuel pump and hard wired the crank sensor because its missing the trans harness part of it.
I can not find any info on this. Only people using the s13 dohc parts to get it to work.
Toplevel4ever is offline   Reply With Quote
Old 06-23-2013, 07:49 PM   #2
Toplevel4ever
Noone has insight on what wires to the ecu need power for it to turn over? I just need to get the thing running. Im not worried about emission things at the moment.
please help!!
I have ecu pinout diagram, and fsm schematics of wiring but just cant get it to turn over.
Old 06-26-2013, 10:19 AM   #3
Toplevel4ever
I think i have power to the ecu where i should. I'm not getting any fuel out of the injectors or i am not getting spark either. Im getting fuel to the rail tho. I see 12v to the injectors but nothing is coming out.
HELP PLEASE! :-)
Old 06-26-2013, 10:30 AM   #4
Link
Link is an unknown quantity at this point
welcome to the most unhelpful place on the internet.
Link is offline   Reply With Quote
Old 06-26-2013, 10:43 AM   #5
Toplevel4ever
lol awesome!!!
Old 06-26-2013, 10:47 AM   #6
Chuki_KA24e
Chuki_KA24e is an unknown quantity at this point
When I did a De swap into my 90' last winter we had the same problem. Crank all day long till the battery is dead but no start. Turns out there is a "starter enrichment something or other" that you need to jump the wires on so it will fire up. Let me go check what color it is, since I'm ghetto and still have my Ecu sitting on my floor lol...
Edit*
Ok it's the orange wire, no stripe, just orange. Make sure it's connected between your Ecu harness and dash harness up behind your glove box. The ecu and harness that came with my De had the dash harness part cut off so, I had to hook things back up. That happens a lot apparently.
Last edited by Chuki_KA24e; 06-26-2013 at 11:04 AM.. Reason: Found the color of the wire I was talking about.
Chuki_KA24e is offline   Reply With Quote
Old 06-26-2013, 10:48 AM   #7
Link
rofl dude that made me laugh.
Old 06-26-2013, 11:16 AM   #8
Toplevel4ever
Edit*
Yes i have that one connected already. My chart says thats for ign/start and it gets 12v when the ign is turned on.
Old 06-26-2013, 11:25 AM   #9
Chuki_KA24e
Well shit, I'm fresh out of useful input...
Old 06-26-2013, 11:36 AM   #10
Toplevel4ever
lol well thanks for that anyways. I appriciate all the help i can get. Im trying to avoid spending a few hundred more dollars on dohc parts from a 91-93 and avoid this whole obd2 crap.
Old 06-26-2013, 12:07 PM   #11
Toplevel4ever
I realized i dont have a map sensor connected. I wonder if this would be a problem. Altho i believe the map sensors on these cars are more for emmisions and not fueling.
Old 07-08-2013, 05:48 PM   #12
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
I having the same problem except my ECU will not turn on and im using all 91-93 DOHC parts
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
