Old 05-29-2011, 09:16 PM   #1
WestTxSR20
WestTxSR20 is an unknown quantity at this point
My SR20 stopped turning over. Already searched. This may stup you.
I am running out of things to replace. My SR20 will not turn over. There is a click, the fuel pump comes on. I'm getting 12V to the starter. The car use to start every once in awhile. I checked the alternator and it's at 13V. The ground wires and power wires looked bad so I ran brand new 4 guage wire strait from the battery and ground and I replaced the ground wire from the intake manni to the battery tray. I also grind the connections to fresh bare metal. I replace the battery and ignition switch. I have 3 used starters I tried and they all tested fine at Autozone. No blowns fuses. I have one new relay switch I have swapped out with all the other relays. Why won't this POS turn over? Should I still try a new starter any ways? I was thinking about attaching a wire where the switch plugges in on the starter and touching it to the battery to see if the starter comes alive.
WestTxSR20 is offline   Reply With Quote
Old 05-29-2011, 09:23 PM   #2
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Uh mm ignitor would be my very first guest.
SLiDe_WaYz is offline   Reply With Quote
Old 05-29-2011, 09:27 PM   #3
harrypotter
harrypotter is an unknown quantity at this point
All I can say is push start it to see if it will actually run, then do from there.
harrypotter is offline   Reply With Quote
Old 05-29-2011, 09:27 PM   #4
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Check the clutch interlock.
di-devol is offline   Reply With Quote
Old 05-29-2011, 09:29 PM   #5
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
starter replay,that sucker almost got me once( i unplugged it and forgot to replug it back ).
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
Old 05-29-2011, 09:31 PM   #6
SLiDe_WaYz
SLiDe_WaYz's Avatar
Yea try that too mine falls off randomly alot.
Old 05-29-2011, 11:09 PM   #7
WestTxSR20
The clutch saftey switch has been removed and disabled for a long time. I thought the ignitor chip just did the spark? My wires I removed from the car were green with corrosion. I feel there is a bad wire some where. I will try swapping out the ignitor chip. I have buddy I can swap parts from his car for trouble shooting purposes. Thanks for the unput. As for the wire that slips off, I soddered on the on from the K24 harness and it stays on pretty tiight. I did check that.
Old 05-30-2011, 01:48 AM   #8
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Can you turn the motor over by hand? Seized engine?
Old 05-30-2011, 02:17 AM   #9
BestOneLeft
BestOneLeft is an unknown quantity at this point
If your starter clicks its getting signal. So your electrical is fine.
I would check to see if the engine still turns manually ,
BestOneLeft is offline   Reply With Quote
Old 05-30-2011, 02:32 AM   #10
tabasco122
tabasco122 is an unknown quantity at this point
push start it first, as was suggested, to make sure it runs, then go from there.
tabasco122 is offline   Reply With Quote
Old 05-30-2011, 09:41 AM   #11
WestTxSR20
I know the engine is good. It wouldn't push start. I dunno if we weren't pushing fast enough or what. Could a bad wire some where cause this?
92 240sx SE Super Hicas 70% repair/restoration/20%Performance/10%Fun
Old 05-30-2011, 03:48 PM   #12
mat.roberts
mat.roberts is an unknown quantity at this point
first thing you should check is the ground on the starter. Then the grounds to the motor. then fuses and other sketch shit. Also download your motors fsm from the internet and it will show you how to properly troubleshoot and all the devices on the car associated with the starter. you gotta be going at a decent speed to bump start.
this emoticon describes me.
mat.roberts is offline   Reply With Quote
Old 05-30-2011, 04:59 PM   #13
WestTxSR20
The motor feels smooth as butter when I turn it by hand. Another thing that might have effected the battery I noticed the battery was shorting out on the hood so today I moved it back to the trunk. There was a hole the size of a nickel caused by the battery touching the hood. I wonder if that could have damaged some thing. Have not got to try the ignitor pack yet. Still waiting on my buddy to bring that by. When I get more time I will go through FSM. I probably should have bit the bullet and done that in the first place. Great stuff gentle men.
Old 05-31-2011, 07:28 AM   #14
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
also the ign switch can do this
if motor turns over by hand then
ur not getting strong enough start signal to stater
jump it with a wire from heavy wire on starter if it cranks
it maybe ur switch
my car does this from time to time
i just keep clicking switch till it cranks
works every time
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
