Old 09-07-2014, 10:42 PM   #1
Dr Ni$mo
Dr Ni$mo is an unknown quantity at this point
HELP!! In serious need of true knowledge!!
Ok so straight to the point
1989 240sx se ka24e stock w/
Ngk "blue" wireset
Bosch platinum spark plugs
New oem fuel pump/ strainer/ fuel filter
Spectre "blue" cone filter
New oem injector o rings/ seals
Now my issue is my cyl #3 pigtail is grounded on both the ground and the power wire. With the key not in the ignition I get constant ground tested via test light. I have swapped ecu's and I chased wires (not to far into the harness since the power and ground wires split off I assumed it was the harness because it didn't happen till I fixed my air leak due to crappy cai couplers so I swapped it out for the oem intake. I'm stumped into what it could be and need help.
Now I don't need dumb answers because I know most of the common issues and I have addressed most (minus the harness which again I don't believe is the problem but a possibility) I'm stumped and need serious help to get my car back
Dr Ni$mo is offline   Reply With Quote
