03-28-2013, 10:06 PM | #331 |
Do you silly fruits mean aluminum, not alloy? Looks like Al; it's smart. I can't find a huge piece of aluminum at work I would also run an alum bumper support.
05-01-2013, 03:41 AM | #333 |
OsGiken -Tiendaracing.net - Lineashel.es Ninocrack.com |
06-18-2013, 04:26 PM | #334 |
we are right now with the wiring, meanwhile I try to have some fun with my old s14
Round 1 Drift spain drift qualifying practice. Ninocrack - YouTube
06-21-2013, 01:46 AM | #336 |
09-04-2013, 05:31 PM | #337 |
wiring
11-20-2013, 04:13 AM | #338 |
12-03-2013, 01:41 AM | #339 |
water temp sensors
12-16-2013, 04:03 AM | #340 |
maserati 4200 front brakes with 320 mm 350z discs with custom machined bracket spacers, seems like they fit well
I was after a GTR R33 ones but finally i´ve got this ones full pics here OsGiken Hel Performance Nissan Silvia S15 2JZ Brakes system | Ninocrack Drifting
12-16-2013, 11:56 AM | #342 |
Don´t know, I´m not in the shop, the custom machined bracket spacer came with the kit, it was for sell at ebay and custom made it to fit the z32, s14, s15
12-16-2013, 06:42 PM | #343 | |
Sent from my SPH-L710 using Tapatalk |
12-16-2013, 10:16 PM | #344 | |
the general rule I use is whp is about 30-40 percent less then bhp. obviously thatll change depending on trans, gearing, final drive...etc. but for the most part that's been correct. |
12-17-2013, 02:41 AM | #345 | |
BorgWarner EFR Turbos | Full-Race.com
OsGiken -Tiendaracing.net - Lineashel.es Ninocrack.com Last edited by ninocrack; 12-17-2013 at 03:02 AM.. Reason: misspelling |
12-17-2013, 02:45 AM | #346 |
650 was our initial goal, right now we expect to get around 500 or 550 at wheels, but I let you know after the mapping
OsGiken -Tiendaracing.net - Lineashel.es Ninocrack.com Last edited by ninocrack; 12-17-2013 at 03:03 AM.. Reason: misspelling |
12-17-2013, 02:47 AM | #347 |
About the wg, I think they are the 38 ones, but right now I don´t remember very well sorry
12-17-2013, 04:25 PM | #350 |
Trader Rating: (18)
Feedback Score: 18 reviews
ohhh I gotcha now. Yeah, it is an internally wastegated turbo, but it's just a photo off the full-race website. the one he ended up getting is externally gated.
https://instagram.com/eck_matthew/ |
12-19-2013, 03:27 AM | #351 | |
01-16-2014, 02:15 AM | #352 |
a lot of plumbing into the waste gates alone, fuel system finished, just need to fit pumps
S152JZ lines | Ninocrack Drifting
02-07-2014, 02:31 AM | #354 |
brakes lines and exhaust ready
S152jz fuel lines finished, brake lines & handbrakes | Ninocrack Drifting
02-07-2014, 05:33 PM | #355 | |
Are those flexlines just for the ebrake or the pedal operation too? |
02-08-2014, 07:42 AM | #356 |
for the 2 handbrakes and the pedal box
02-08-2014, 03:51 PM | #357 |
It´s running there is a faulty coil but it´s running fine
Ninocrack Nissan Silvia S15 2JZ First Start. Primer arranque - YouTube
02-11-2014, 11:46 AM | #358 |
So you're running the teflon lined stuff throughout from even your pedal box? Are you not concerned with flex and/or burst? I know our max pressure is right around the burst pressure of -3AN lines which shouldn't bode well for racing/drifting applications... I know the swagelok lines have about 1000psi higher burst pressure than earls and such though.
02-22-2014, 01:08 AM | #359 | |
http://youtu.be/bWsDsduAKa8
02-28-2014, 02:01 PM | #360 | |
