08-21-2020, 10:21 AM | #1 |
2001 Lexus IS300 NA-T (6266, R154, AEM V2, 500WHP)
https://imgur.com/a/NWJt6Fw Just gonna put a few photos on here and then link the group below, they're really big! Asking 17k obo, very happy to negotiate but no lowballing. Has cold AC, heat, PS 2001 IS300 GGP Clean Title 200k chassis 70k on build Engine: GTE pistons and rods ACL rod bearings ACL journal bearings Arp head studs Arp rod bolts GTE MLS head gasket New valve seals New valve cover seals New front, rear, cam seals New timing belt New serpentine belt New water pump and thermostat New bkr7e spark plugs New NGK spark wires New valve cover gasket New exhaust manifold gaskets Precision Injectors Haltech F10X ecu New precision 6266 powder coated compressor housing Cerakoted SRT turbo manifold Cerakoted HKS wastegate Cerakoted turbine housing Cerakoted dump tube New silicone vacuum hoses Oil filter relocation kit SRT intercooler GM IAT sensor GM coolant temp sensor AEM 3.5 bar map sensor Aeromotive fpr Aeromotive stealth 340 e85 ready AEM V2 6050 DEZOD pnp harness Tuned by Trilogy Performance Transmission: MK3 R154 Suprasport V3 short shifter Southbend 600 ft lbs torque clutch Fresh motul tranny fluid New output shaft seal New release bearing New AISIN slave cylinder New AISIN master cylinder New Driftmotion flywheel New Driftmotion flywheel locking plate ARP flywheel bolts OEM pressure plate bolts Interior: AEM UEGO wideband AEM TruBoost gauge and controller AEM oil pressure gauge New pioneer Double Din New JBL component speakers all around New Rockford fosgate powered sub 2IS steering wheel with working paddles and radio buttons No seat tears LED cluster lights LED climate control lights Suspension: Tein street master flex z with electronic damper control New lower ball joints New SPL camber bolts Front upper control arm camber ball joints New inner and outer tie rods Megan racing front brace New gs300 rear upper control arm New Xcessive diff bushings New Megan subframe collars Misc: Michelin AS3 245/40/18 with only 8k miles Vibrant ultra quiet resonator 3" downpipe, 4" axleback New pads and rotors all around New rear wheel bearings M98 LSD Xcessive clutch pedal Front and rear dash cams Tow hitch receiver Last edited by asianleful; 11-14-2020 at 02:51 PM.. |
