Old 07-18-2008, 12:00 PM   #1
Saviorsoul
Saviorsoul is making his/her stupidity well-knownSaviorsoul is making his/her stupidity well-knownSaviorsoul is making his/her stupidity well-knownSaviorsoul is making his/her stupidity well-known
KA Unstable and random idle
s13 ka24de
Some reason I just CAN NOT get my car to idle properly. Its eratic and random! I can't figure out what the hell it is..
What I've tried to fix it:
Searched high & low for vacum leaks
Replaced TPS, calibrated correctly
Replaced lower collector w/ IACV off a running motor
MAFS is new
Checked grounds and fuses, all ok..
Yeah, so I'm out of ideas. Anyone else have some?
(Emissions removed) New rebuilt motor
Saviorsoul is offline   Reply With Quote
Old 07-18-2008, 12:06 PM   #2
Phlip
Phlip's Avatar
I don't see anything suggesting that you've checked ignition (plugs/wires, coilm, etc.) or injectors... Have you?
And I write too!
Old 07-18-2008, 12:09 PM   #3
jyb116
Banned from the Marketplace
jyb116 is an unknown quantity at this point
could be exhaust leak thats what happend when i got mine
jyb116 is offline   Reply With Quote
Old 07-18-2008, 12:14 PM   #4
Saviorsoul
plugs new (took out and cleaned as well)
Checked wires (If I take them out they all produce a substancial loss in engine speed)
MSD Coil2 (new)
Injectors new as well O-rings installed correctly.
Old 07-18-2008, 12:16 PM   #5
Saviorsoul
... I have a penny sized exhause leak, but I can't see how that could cauase my idle to be eratic.. I'm trying to find pair of Hotshot 4-2-1 ceramic coated headers to fix my exhaust leak, and get better performance at once... (fuckn shity pacesetters)
Old 07-18-2008, 07:48 PM   #6
osal
osal is making his/her stupidity well-knownosal is making his/her stupidity well-knownosal is making his/her stupidity well-knownosal is making his/her stupidity well-known
tryin running some seafoam, it help alot estabilizing my idle.
Also check ur ignition timing
osal is offline   Reply With Quote
Old 07-18-2008, 08:12 PM   #7
singlecamslam
Try the EGR and try to run engine codes.
singlecamslam is offline   Reply With Quote
Old 07-18-2008, 08:15 PM   #8
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
I did a write-up on this, search for it!
racepar1 is offline   Reply With Quote
Old 07-19-2008, 11:46 PM   #9
Saviorsoul
Its a new motor, doesn't need seafoam, BUT I did it anyway. No help
Old 07-19-2008, 11:47 PM   #10
Saviorsoul
I don't have emissions. An I don't have a check engine light either.
Old 07-20-2008, 09:24 AM   #11
blownoffvalve
blownoffvalve is an unknown quantity at this point
wow i didnt know an exhaust leak would actually cause this problem
blownoffvalve is offline   Reply With Quote
Old 07-20-2008, 12:26 PM   #12
racepar1
racepar1's Avatar
Like I told you SEARCH for my write-up! Stop being an idiot and listen! I'm not going to hold your damn hand, but I will point you in the right direction!
Old 07-20-2008, 12:51 PM   #13
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Exhaust leak the size of a penny? Yea.......not good, And emissions are directly inline with your vac system, even when capped off. Isnt the Evac constantly purging?
Clean out the IACV, check the alternator load.
Bigsyke is offline   Reply With Quote
Old 07-20-2008, 01:05 PM   #14
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
Might wanna try to clean the Intake Manifold and replace a new Knock sensor.
Due to the old KA there will be alot of carbon stick inside the manifold so it could cause engine performace and idling problem. Also it could casue the EGR not working properly so try to clean the Manifold.
pink godzila is offline   Reply With Quote
Old 07-20-2008, 02:39 PM   #15
racepar1
racepar1's Avatar
I give up!
http://zilvia.net/f/showthread.php?t...light=idle+fix
Old 07-20-2008, 02:41 PM   #16
phi_ho1
phi_ho1's Avatar
Trader Rating: (57)
phi_ho1 is making a name for him/her selfphi_ho1 is making a name for him/her self
Feedback Score: 57 reviews
Send a message via Yahoo to phi_ho1
best is to check the MAF. 75 percent is will be it.
phi_ho1 is offline   Reply With Quote
Old 07-20-2008, 02:49 PM   #17
racepar1
racepar1's Avatar
WRONG! MAF's rarely go bad, especially on nissans. Is anybody going to read the damn thread that I wrote? I mean what the hell! People were bugging the hell out of me to write it, and nobody wants to read the damn thing!
Old 07-20-2008, 04:59 PM   #18
red240
red240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the rough
I read it,good job! Going to do it to as I have Idle problems with my s14sr
Mine runs fine for a few min. then stumbles then idles good again randomly
red240 is offline   Reply With Quote
Old 07-22-2008, 09:52 AM   #19
Saviorsoul
lol just listening to their ideas. I found your write up. I just haven't had enough free time when its not 103 degrees F in the shade out here. I'm going to try it, it makes sense and if its helped two of your friends I'll damn well try it.
Old 07-22-2008, 09:54 AM   #20
Saviorsoul
.90 percent of the time IF the MAFS goes out you encounter a 2300RPM (rev limiter) Your car pretty much won't allow you to rev past 2300. I don't know if its a saftey protocol, or just from it being fucked up, but I've encountered it on two 240s. My MAF did go bad, but I replaced it and its fine now. I can use my full rev band. Thanks for the idea though.
Old 07-22-2008, 10:01 AM   #21
Saviorsoul
Read my origonal post. Its a rebuilt motor. My intake was sandblasted. There is NO carbon build up and my knock sensor is fine, plus all the sensor does it retard your timing if it senses a knock, and when it goes bad it almost always throws a code. (Plus its new, OEM from Nissan)
Old 07-22-2008, 10:03 AM   #22
Saviorsoul
I don't live in So Cal. I have no emissions.
Old 08-01-2008, 11:31 PM   #23
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
No, actually we blew up the MAF.
And goddamnit Eric don't fucking post a million times. Ctrl+C is your friend when trying to quote multiple posts.
My idle is a bit erratic myself lol. But I've got more on my plate after that fiasco last night.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
