Old 07-10-2010, 11:52 AM   #1
hdz123
hdz123 is an unknown quantity at this point
Bogging issue low rpms?
Hey so I've been having a bogging issue with my car, it runs fine when it is cold, unlike others people's problems i have heard, and gets progressively worse. Feels like it is almost stalling but is okay after around 3k rpm's. I just replaced my fuel pump with a Walbro, and gunna do the fuel filter today. Any suggestions of what else it can be?
hdz123 is offline   Reply With Quote
Old 07-10-2010, 01:44 PM   #2
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
might be a dirty maf.
clean your maf sensor with sensor kleen.
1992 240sx (RB20. [email protected])
eklips3 is offline   Reply With Quote
Old 07-10-2010, 04:10 PM   #3
hdz123
I cleaned the maf before.
Old 07-10-2010, 04:13 PM   #4
Goodlucks7even
Goodlucks7even's Avatar
Goodlucks7even is an unknown quantity at this point
Little cracks onto the air intake may cause those problems, verify couplers and any junction. Does it smokes ?
Goodlucks7even is offline   Reply With Quote
Old 07-10-2010, 05:49 PM   #5
hdz123
It only has the problem when it gets warm. It has a ck code of misfire # 3. just changed the plugs, cap and rotor.
Old 07-11-2010, 05:44 PM   #6
hdz123
Angry
car will idle perfect, then start to miss, after a while it clears up. vac hoses look good. What could it be??
Old 07-11-2010, 05:48 PM   #7
s13coupe1988
s13coupe1988's Avatar
s13coupe1988 is an unknown quantity at this point
Tps check that out
s13coupe1988 is offline   Reply With Quote
Old 08-21-2010, 04:01 PM   #8
timothy2t
timothy2t's Avatar
timothy2t is an unknown quantity at this point
check all your fuel lines for kinks
timothy2t is offline   Reply With Quote
Old 08-21-2010, 04:11 PM   #9
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
adjust the tps to 45-50 with a volt meter, if not than check maf sensor and its connection. if still no fix than start the car and play with the egr. with the car running, lift the egr open and your car should die, it should move fairly easy and that will tell if egr works propperly.
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
Old 08-23-2010, 09:48 AM   #10
tommytwo40hands
tommytwo40hands is an unknown quantity at this point
this wouldn't cause it to run like crap after it gets warm..if the lines had kinks it would run like crap right after you start it..maybe a bad filter...does it miss when it's idleing? check you wires for any burnt spots, could also be the plugs maybe..
tommytwo40hands is offline   Reply With Quote
