Old 11-06-2005, 03:37 PM   #1
ter-tech
ter-tech is an unknown quantity at this point
Ter-Tech presents 2 Day Drift/gymkhana parking lot N0V19-20
Nov 19th and 20th we will have a two day drift/gymkhana clinic at the Dania Jai Alai sport center parking lot at 301 E Dania Beach Blvd Dania, FL 33004-3016 . To pre reg. go to www.ter-tech.com This is the first two day parking lot event in Florida. Pre reg. is only $100.00 for both days GO TO www.ter-tech.com TO PRE REG. Registration will close on Nov. 13th after that it will be $140.00 no exceptions. Gates will open Saturday at 9AM and stay open till 8PM, Sunday gates open at 1AM till 8PM. Bring your own chairs since there will not be stands. This is the event that whole state has been waiting for practise without the worry of walls. Pre reg. will be limited to 40 drivers so act fast.
As usual there will be vehicle, helmet and driver inspection.
Check all of following:
1. __Fluids Leaking
2. __Tires and Lug nuts
3. __Front-end & Steering
4. __Rear end
5. __Exhaust hanging
6. __Bumpers secure
7. __Seat belts
8. __Helmets
9. __Clean Trunk & Interior
10. __Battery secure
11. __Air Filter
12. __Loose components under Hood
13. __Doors operation
14. __Hood & Trunk Latches
Rules and Regulations
Please read carefully:
1. Make your car as safe as possible.
2. Batteries and air filter systems must be secured.
3. No excessive fluid leaks, oil, water, etc.
4. Tires must have good tread.
5. All interior and trunk areas cleared of items. (Tires, jacks, tools, etc.)
6. All lugs and lug nuts must be on and tighten properly.
7. Seat belts must be worn at all times while on track.
8. A racing helmet must be worn at all times while on track.
Track officials have the right to deny some types of helmets from being used for safety purposes.
9. Both hands must remain inside car while on track.
10. Driver window must be closed while on track.
11. Follow, only, the course that you have been shown. Do not deviate from the course unless instructed to by a track official.
12. If you spin out, drive car back on course. NO SMOKEY BURNOUTS or DONUTS are needed. Doing this will only take away from your performance.
13. No POWER BRAKING, DONUTS, BURNOUTS, or DRIFTING in undesignated areas. (Parking lot, staging area, etc.
Please follow all Rules and Regulations. Failure to do so may result in immediate expulsion from event. Continuous disrespect may result in being banned from future events. Your cooperation is needed and expected. Your safety is most important to us, and your responsibility. Do not Drift beyond your capability. Know your limitations.
THANKS FROM ALL OF US AT
TER-TECH
ter-tech is offline   Reply With Quote
