Old 06-23-2016, 02:09 AM   #31
Charlie_91
Charlie_91 is an unknown quantity at this point
Wheels arrived. Was unsure how they would look but came up pretty good. Heres a bunch of pics.
Specs: 18x9.5+0 and 18x11-18
Fronts
Rears
Charlie_91 is offline   Reply With Quote
Old 06-23-2016, 03:24 AM   #32
chank
chank's Avatar
chank is an unknown quantity at this point
those wheels are schweet!!
chank is offline   Reply With Quote
Old 06-23-2016, 04:30 AM   #33
VenomKillz
VenomKillz's Avatar
VenomKillz is an unknown quantity at this point
Love the fact you're going to use 326 Power coilovers. +1
VenomKillz is offline   Reply With Quote
Old 06-23-2016, 05:17 AM   #34
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
nice op. I had a roof issue(my hood smacked my roof) good to know all you have to do is replace the skin.
supersayianjim is offline   Reply With Quote
Old 06-23-2016, 09:26 AM   #35
scottie
scottie's Avatar
Them wheels!! I can already picture the stance. Keep the updates coming.
IG: @scotheocelot
Old 06-23-2016, 09:37 AM   #36
jsu1012
jsu1012's Avatar
jsu1012 has a spectacular aura aboutjsu1012 has a spectacular aura aboutjsu1012 has a spectacular aura aboutjsu1012 has a spectacular aura aboutjsu1012 has a spectacular aura aboutjsu1012 has a spectacular aura about
Oh man this is going to be good! T7r 2 piece was a great choice.
jsu1012 is offline   Reply With Quote
Old 06-30-2016, 12:04 PM   #37
Street_raiders
Street_raiders is an unknown quantity at this point
Are you staying 2 tone? Trying to picture how this will look with the T7rs, very nice wheels
Street_raiders is offline   Reply With Quote
Old 08-28-2016, 04:54 AM   #38
Charlie_91
Hey guys,
Long time no update. Ive been busy doing a lot of little stuff to it. Continued on the wiring. Front and rear looms all done just concentrating on the engine loom atm but shouldnt be too far off. Unfortunately no pics but it looks pretty with the sleeving :')
Also decided to run the loom through behind the motor so i shave the last hole on the firewall. Its not fantastic but its pretty good so should be good once painted.
Bought some new engine mounts mainly because i needed to sit the motor in to work out exhaust manifold.
On the topic of exhaust manifold, this is what Terry and I came up with. Its like a forward low mount type thing. Because my ps pump is in the boot we decided to do something different. Came up really cool and looks pretty badass in the bay so happy with that. Just need to do the gate hole etc and its done
Also finalising the suspension. Subframes and stuff are off getting powder coated atm. My heatmaker steering setup came in as well. Then just decided to clean up my LCA's and Rear knuckles as these will be staying stock for now.
Finally the ecu and patch loom. Nothing fancy or new but should do the trick.
Other then that, the roof has been welded back on so will start to finalise everything and start paint prep so i can get it paint and rolling. Exciting times.
Old 09-29-2016, 04:03 AM   #39
Charlie_91
Update:
So finally got all the pieces to put my suspension together.
Front Setup consists of:
- 326 coilovers
- heatmaker knuckle/lca combo
- Gktech v3 castor arms
- Relocated steering rack
- PBM steering rack bushes
- Solid steering shaft spacer
Rear:
- 326 Coilovers
- Gktech v3 camber, toe and traction arms
- Solid subrame bushes
- Reinforced Subframe
Heres some pics
Also test fitted the motor and manfiold on. Excited for this !
Old 09-30-2016, 04:34 AM   #40
tricky_ab
tricky_ab's Avatar
This car is going to be too cool!!! Love the custom manifold by the way.
Instagram
Old 09-30-2016, 04:26 PM   #41
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Watch him just quit mid build. Not like we havent seen that already...
;p
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 09-30-2016, 05:16 PM   #42
Charlie_91
;p
lol I haven't quit mid build. I've sold cars once they were finished and I wanted to do something different but that's about it...
Old 10-01-2016, 11:02 AM   #43
tb13
tb13's Avatar
tb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to alltb13 is a name known to all
Damn, this thing is coming along nicely. Will be following this build for sure!
tb13 is offline   Reply With Quote
Old 10-01-2016, 11:14 AM   #44
RB25GUY
RB25GUY's Avatar
Originally Posted by Tucker240 View Post
Tubs and GReddy TD06-20G <3
fixed that for you
this beast is already looking promising!
Old 10-01-2016, 11:15 AM   #45
tuzzio
tuzzio's Avatar
That manifold is awesome.
Old 11-23-2016, 03:30 AM   #46
Charlie_91
Thought id update because ive been doing a lot of shit haha. So to start off with. made some brackets, kept going with wiring and looped heater lines.
Next up I installed cams with the help of a friend and got the cooler pipes/header tank setup fabbed up.
Stripped it down to a complete bare shell and painted the insides Audi Nardo Grey.
Kit Came in
Overs came in. Fluked the fitment on this. Was kinda worried they wouldnt fit the wheels but it just made it.
Had to mock it up together !
Time to reassemble and get it running
Old 11-23-2016, 04:16 AM   #47
octanejockey
octanejockey's Avatar
octanejockey is an unknown quantity at this point
That low mount turbo looks sweet! Have you figured out where you're going to mount the scavenge pump yet?
octanejockey is offline   Reply With Quote
Old 11-23-2016, 01:05 PM   #48
Charlie_91
Doesn't look like it but the oil drain flows down still so no need for scavenge pump
Old 11-23-2016, 01:27 PM   #49
offthewall
offthewall's Avatar
offthewall is making a name for him/her selfoffthewall is making a name for him/her selfoffthewall is making a name for him/her self
Yeah man! I like it.
p.s:
I want to steal your wheels.
Whalen's Speed R&D - IG - @MachinegunSquad - www.whalentuned.com
offthewall is offline   Reply With Quote
Old 11-25-2016, 08:41 PM   #50
tricky_ab
tricky_ab's Avatar
Car Modify Wonder! Man, this is one of my current favorite builds!
Instagram
Old 11-25-2016, 09:02 PM   #51
Standard
Hell yeah! Nice progress!
Old 11-25-2016, 09:06 PM   #52
Kalem_s13
Kalem_s13's Avatar
Kalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymoreKalem_s13 is not welcome here anymore
Looking good man, what size are these over fenders? Keen to seeing some more quality work!
Kalem_s13 is offline   Reply With Quote
Old 11-25-2016, 11:34 PM   #53
octanejockey
Right on, even better! You've got a great looking build so far, I'm so jealous of your shaved / tubbed bay... It's a long way off on my to-do list, lol.
Old 11-26-2016, 12:15 AM   #54
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
you're my hero!
joshchewuhh is offline   Reply With Quote
Old 11-29-2016, 12:12 PM   #55
Ronald_Mcdonald
Ronald_Mcdonald is on a distinguished road
Send a message via AIM to Ronald_Mcdonald
Damn, that's so good.
Determined to be famous, destined to be infamous.
Ronald_Mcdonald is offline   Reply With Quote
Old 11-29-2016, 03:11 PM   #56
Habibi240
Habibi240's Avatar
Habibi240 is an unknown quantity at this point
Looking amazing . Subd
Habibi240 is offline   Reply With Quote
Old 11-29-2016, 06:46 PM   #57
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
gonna take a lot to top the last s13 but i think this has it covered for sure, are those origin type 3 rear overfenders?
Old 11-29-2016, 10:34 PM   #58
Malik
Malik's Avatar
im excited for this
Old 11-30-2016, 08:42 AM   #59
TheRealSy90
TheRealSy90's Avatar
I cant get over the fact that you weren't happy with the old green/blue s13, cause that car has been my top 3 silvias next to TJ's old black silvia, and Streeter's white silvia.
However this new car is really coming together and looks amazing. Any chance I could purchase one of those heater loop line setups? I don't like the one I made very much.
Such a good signature.
Old 12-01-2016, 11:35 AM   #60
gbaby2089
gbaby2089's Avatar
This is way good thus far.
s13, sr20, td06
