Old 10-07-2009, 01:23 PM   #1
maddashin
maddashin is an unknown quantity at this point
Question starting problems with ka24de
okay so i hate for this to be my first post but haven some serious issues with my 240. it is a 1993 super hicas stock motor. i bought from a guy for 600 and he thought the injectors was bad. well i replaced the injectors and still no start up. it will turn over but wont start. i am getting smoke coming out of the intake. any ideas will help. i pulled a spark plug out and put it on the block so i got spark for sure. this is my first nissan and ka24de to work on, so please if i need to check certain items, good instructions to where it might be will be very helpful.
maddashin is offline   Reply With Quote
Old 10-09-2009, 01:33 AM   #2
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
check your timming..sounds like its off a tooth or so.reset it n see what happens.if thats good see if it will start with starter fluid with the fuel fuse pulled out if ya timing is good
project-D180 is offline   Reply With Quote
Old 10-09-2009, 01:34 AM   #3
project-D180
i mean cam timing at the distributer.set your car to tdc line ya rotor up wit spark plug 1 n go from there
Old 10-09-2009, 08:55 AM   #4
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Check EGI/fuel pump fuses. Take off the line going to the fuel filter and make sure gas is getting to the injectors. Could be a harness issue. You need to eliminate some more stuff before we can give you better advice.
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
