Old 04-08-2010, 07:24 PM   #1
SrRaycer
SrRaycer is an unknown quantity at this point
BC cam timing...
I have a set of 272 cams for my s13 sr. I have read that the exhaust cam will be way off timing with the stock sprockets, does anyone have knowledge or experience with this?...I have done countless searches, Thanks
SrRaycer is offline   Reply With Quote
Old 04-08-2010, 08:18 PM   #2
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
don't quote me, but i thought that was only for true for certain batches of the cams that were produced....
don't count on it tho!
Daily driven
jspaeth is offline   Reply With Quote
Old 04-17-2010, 01:36 PM   #3
tricky_ab
tricky_ab's Avatar
I've heard that the timing is usually off with these cams. I had a friend who has a set of 264 and his timing was off from the get go...
Old 04-17-2010, 02:25 PM   #4
army240
army240's Avatar
army240 is an unknown quantity at this point
Yeah, you should buy a set of cam gears to go with those cams... that's what I did. After that, put the degree wheel to time them properly!
Frank
army240 is offline   Reply With Quote
Old 04-25-2010, 11:12 AM   #5
SrRaycer
Thanks for the responses guys. I will get a set of sprockets, but I dont have a degree wheel because I bought the cams used. Do any of you know where I can get one or have any other suggestions?
Old 04-25-2010, 02:13 PM   #6
tacoboy
tacoboy is an unknown quantity at this point
Timin is off big time. You need adjustable gears, a dial gauge, and a degree wheel. Took me 8 hours to get it all figured out. Good luck!
tacoboy is offline   Reply With Quote
Old 04-25-2010, 03:42 PM   #7
SrRaycer
8 hours to get the timing figured? hopefully i can get it done quicker than that. ^^^what was your timing before adjusting your sprockets? which BC cams do you have?
Old 04-26-2010, 04:44 PM   #8
tacoboy
272's. Its a VERY strenuous process, and you need to know how to do all of the math in order to get it right. Remember, it's not crank timing, its cam timing, not as simple as moving a CAS...
Old 04-26-2010, 05:58 PM   #9
army240
army240's Avatar
FYI, degree wheels don't come with a new set of cam... it's not like a clutch alignement tool...
And also, you have to know the entire process, and make sure you know it by heart, understand it so if something happen, you will know why. It also takes a dial gauge. If you plan to do that yourself, I hope you know how this work.
Frank
Old 04-26-2010, 08:51 PM   #10
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
im just going to take my car to a shop and have them time my cams
Options13 is offline   Reply With Quote
Old 04-27-2010, 11:16 AM   #11
SrRaycer
ok i found some degree wheels on ebay, will these work or do i need a certain one?
If these will work then what size do you suggest i buy?
and do i really need the dial guage?
Thanks
Old 04-27-2010, 02:38 PM   #12
army240
army240's Avatar
Yes, it REALLY does!
