Old 08-20-2012, 11:33 AM   #1
justin_bfn
justin_bfn's Avatar
justin_bfn is an unknown quantity at this point
rb20 running problems
I just put a rb20 in my coupe and it was running good for an hour so then out of no where it started to sputter like crazy and run rich. then when i turned it off it was now hard to get going again. I've been told things as maf vacuum leak somewhere or faulty injector maybe. But if it was something fuel related that was faulty wouldn't it have been doing that from the start? someone please help.
justin_bfn is offline   Reply With Quote
Old 08-20-2012, 01:09 PM   #2
cotbu
cotbu's Avatar
Probably temp related, which in return controls fuel. So no you wouldn't notice from the start! Don't hesitate to check everythang, everythang that's right everythang; look out for your star player pimpin!
Old 08-20-2012, 01:51 PM   #3
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
couple things. important things. please check
1) did you tighten your CAS. ive done it.
2) do you have ample chassis - engine grounds and are they tight . done this too.
3)your engine wouldve heated up in an hour. doubt its coolant temp sensor..
4) when does it sputter. exactly.
ch1873857 is offline   Reply With Quote
Old 08-20-2012, 01:54 PM   #4
justin_bfn
justin_bfn's Avatar
cps is new and all grounds are good i haven't checked CAS yet will do that. and it sputters anytime even if you just rev it it sputters.
Old 08-20-2012, 05:31 PM   #5
ch1873857
so the car isnt even driveable...
sounds like you blew a coupler off
rb20 s13, rb20det, s13 coupe
