S13 SR20det Fuse box problem to S14 chassis
I have a Redtop wired to the S14 kouki chassis all setup
but the engine bay fuse box which wires into the car also doesn't seem to be. the previous owner used a SE model fuse box but the car is a base and so the extra security immobilizer relay is causing some problems... how do I fix this?
can i just buy another Base model wire harness? btw what do you call those wires and fuse box anyway? i can't seem to find it online..
any help would be appreciated at this point I'm looking to just buy another Base model fuse box that doesn't come with the extra immobilizer relay thingy and need to know where to find one.
or if the painless universal circuit board kit is a direct replacement and if the painless circuit board replacement kit allow A/C to work in the car.
