Old 06-03-2008, 03:12 PM   #1
gthbryce
gthbryce is not welcome here anymoregthbryce is not welcome here anymoregthbryce is not welcome here anymoregthbryce is not welcome here anymoregthbryce is not welcome here anymoregthbryce is not welcome here anymoregthbryce is not welcome here anymoregthbryce is not welcome here anymoregthbryce is not welcome here anymore
Help with removal of fanclutch and waterpump pulley
Ka24de stock.. I need to replace the water pump because bearings are goign out. I have remove everything in the way to get access to it. THe fan clutch is still on the water pump I assume i remove that first? How do I go about doing that?
gthbryce is offline   Reply With Quote
Old 06-03-2008, 03:18 PM   #2
murda-c
murda-c's Avatar
Four 10mm bolts on the fan, four 10mm nuts holding the clutch and pulley on.
also you should loosen the belt tensioner, i think it's on the Power steering pump.
Old 06-03-2008, 04:36 PM   #3
gthbryce
How do i move the belt tentioner
I lossened the bolt on the tentioner which is on the power steering but which way and how do i move the thing...It seems like its never been moved so it very well may possibly be caked on. please help
Old 06-16-2008, 12:36 AM   #4
Bboy/dorikun88
Bboy/dorikun88's Avatar
Bboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the rough
Send a message via AIM to Bboy/dorikun88
yeah i did a water pump replacement couple months back on my car and the tensioner didn't move either all i did was make shure the bolt was loose and hit the tensioner bolt down with the end of the hammer and it went down dont kno if thats any help but here ya go.
Bboy/dorikun88 is offline   Reply With Quote
Old 06-16-2008, 02:20 AM   #5
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
smack it..... so it gets loose... after loosening... then unbolt the clutch fan...... replace the belt.... also... if it looks old while ur at it...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-16-2008, 05:23 AM   #6
Sileighty_85
Sileighty_85's Avatar
There are two things you have to loosen on the PS to move it (easily)
1) the lower nut for the tensioner
2) upper pivot bolt. Its behind the pully, spin the pully and look through the holes on the pully and you will see it, just loosen it and you should be able to push the PS pump down.
as everyone said before for the fan
1)grab 10mm wrench
2) remove all 4 nuts from WP
3) smack the crap out of it 180* apart simulaniosuly
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-19-2008, 08:06 PM   #7
gthbryce
*Progress Update* Please Help
After took the fan off I'm left with the fan clutch, waterpump pulley and waterpump still on the car. I have been trying to remove four nuts from behind the clutch but whenever I turn it, it turns the pulley with it; I even tightened the belt. I have gotten two nuts off so far, that was by using an ajustable wrench and a 10mm wrench. The adjustable wrench keeps slipping and I have two bolts to go. I'm assuming I need to purchase another 10mm to hold one nut to stop the pulley from moving while I loosen the nut with the other. But what happens when there is only oen nut left? How am I supposed to stop the pulley from moving when I try to loosen the last nut? ... Am I doing this all wrong? Btw it seems like this fan pulley has not been removed for a very long time and I have sprayed tons of PB bolt lossener on all the nuts. I need to get the clutch and pully off so I can get the water pump off and get the new one I purchased on A.S.A.P. Please help!
Old 06-20-2008, 10:52 PM   #8
MangoDorifto
MangoDorifto's Avatar
MangoDorifto is an unknown quantity at this point
The trick is to take the fan and clutch assembly off together as one young grasshoppa. Take a prybar (or screwdriver) and wedge it between the stud and pulley, opposite of the nut your trying to take off. hold the pulley in place with the prybar in one hand and break the nut loose with your free hand.work smarter not harder
MangoDorifto is offline   Reply With Quote
Old 06-22-2008, 02:43 PM   #9
gthbryce
Thanks
Haven't tried this yet but hopefully it works
