Old 07-30-2009, 05:07 PM   #1
kassed33
kassed33 is an unknown quantity at this point
s14 300zx master cyclinder into 240 help!
I have a 95 240 with z32tt front brakes and stock rears. I'm looking to improve my braking by swapping the MC. So I'm wondering which model an year should I get it from.
josh kassed
kassed33 is offline   Reply With Quote
Old 07-30-2009, 05:52 PM   #2
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Swapping the MC really isnt necessary until you swap to the Z32 rears as well. You will need the 17/16th MC and make sure it has the middle fitting installed already. Nabco is the OEM unit.
My SR20VET
Old 07-30-2009, 10:21 PM   #3
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
It will feel a tad squishy, with the front 4 pot calipers, and stock manual brake booster.
I would just order the S14 automatic brake booster/MC from courtesy nissan. If you switch out to the 300z brake MC you will have to modify the hard lines a bit. With the s14 automatic brake booster/MC you wouldn't have to do that.
You should read about the definitive 300z brake swap.
The Definitive 300ZX Brake Swap!
BigVinnie is offline   Reply With Quote
Old 07-30-2009, 11:11 PM   #4
projectRDM
projectRDM's Avatar
Exactly. Auto unit is 15/16", up from 7/8" on the manual. That doesn't sound like much but it's a large increase in pressure. Plus it bolts right up.
FORMERLY R240NA
Old 07-31-2009, 07:13 AM   #5
BigVinnie
BigVinnie's Avatar
The only time I would use the 300z MC is on the s13 chassis because the hard lines mount right up. S14 though is a no brainer it would have to be the s14 auto brakebooster/MC. It just looks cleaner that way and it isn't as stiff as the 300z MC. The auto s14 booster/MC actually glides really smooth, and doesn't have any squishy.
If the car is non ABS the s14 auto brake booster/MC also glides better, and won't lock up as soon as the 300z MC would.
If the driver wants more pedal feel for the s14 auto brakebooster/MC, then it would be better to up grade to steel braided brake lines.
The s-chassis is 680LB.s lighter than the 300z chassis, using the 300z mc is a little over kill for non ABS systems.
Old 07-31-2009, 07:24 AM   #6
bansheeracer2003
Trader Rating: (28)
bansheeracer2003 is an unknown quantity at this point
Feedback Score: 28 reviews
u should go check out silverminemotors.com they have all the brake parts u need for your 240 and there even coming out with a rear kit in a little while!
-Ron
bansheeracer2003 is offline   Reply With Quote
