Old 03-02-2010, 10:27 AM   #601
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
im might just have to take ur offer, because it seems they might be on back order from my supplier...
do me a favor, take pics of the tire wear with a penny, so i can see the tire wear mark...if there only 90% then yeah
either that or ill buy some Goodyear Eagle GT's...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 03-02-2010, 11:46 AM   #602
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
cool...I will try to get some pictures for you by the weekend.
Maiku240sxS14 is offline   Reply With Quote
Old 03-02-2010, 11:46 AM   #603
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
please...that would be great...and thank you...i wann try and have them mounted by sunday...
PSN
Old 03-02-2010, 11:54 AM   #604
Maiku240sxS14
Trader Rating: (37)
damn...ok then, I'll go and take some pictures now....and send them thru PM.
Old 03-02-2010, 12:10 PM   #605
fckillerbee
fckillerbee's Avatar
Originally Posted by YoungGun View Post
215/40/17.
correct
Old 03-02-2010, 12:18 PM   #606
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
psi^?... IMA get them swapped into the fronts and just use up the nankangs in the rear, and th eother 4 tires i bought prior as well
PSN
Old 03-02-2010, 12:18 PM   #607
fckillerbee
30 front 50 rear. then we'll go from there.
Old 03-02-2010, 12:23 PM   #608
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Kew ^, and i already hammered out the wheel wells, and the pump is getting rebuilt...
should be ready...one thing i cant do is lower the car since im not sure how much to do it...does measuring 1'' of threading = 1'' of dropped height...or, am i totally off on this?
PSN
Old 03-02-2010, 12:25 PM   #609
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
broo hes rocking CA.
50 rear is way too much.
nieko is offline   Reply With Quote
Old 03-02-2010, 12:26 PM   #610
fckillerbee
bro...i drove that CA....and 50 is fine.
Old 03-02-2010, 12:29 PM   #611
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
bro!
sounds liek you need to drive the car...
you have a point sir...
PSN
Old 03-02-2010, 12:37 PM   #612
fckillerbee
bro!
measuring the colar drop 1 inch will drop the car an inch. just make sure the spring isn't under load, or too much load....needs to be just right. I measure the gap in fender when the wheel is turned, then drop the car that much. keep in mind about 1/2 inch to 1 inch for body roll (clearance).
make sure you triple check your measurement...don't want teeder todder like mr jxn.
Old 03-02-2010, 12:39 PM   #613
nieko
weird.. what is wrong with your CA? LOL
i put 40psi in cold and there was still waaaay to much tire spin last event. lol
Old 03-02-2010, 12:48 PM   #614
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
so wait wait wait...do i mess with the section that connects to the knuckle? or do i actually mess with the colars holding the spring...?!
do you see what i mean about me and coilovers!!!
nothing is wrong with it, i just gotta learn it sir...my motor is stock...max itll push is 175, if that...
PSN
Old 03-02-2010, 12:51 PM   #615
mehsilvia
mehsilvia's Avatar
mehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfection
Steve needs his own thread.
Or a search
And you do need to lower that bitch. Fucking monster truck status BRO. Body rollin like a motherfucker out there. At least you got some of the dampening adjusted that day.
I can help ya out Steve
With coilovers, it IS just that simple.
Taking a tape measure to the collars, measuring out an inch, spin it, ur now down an inch!
Or 4 in your case
mehsilvia is offline   Reply With Quote
Old 03-02-2010, 12:58 PM   #616
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Or a search
Or 4 in your case
im NOT down to slam the btich...last thing i need to do is worry about were my 2x4's are to get the car off the trailor...
ill drop it another 1 1/2'' in the front, maybe 1/2'' in the rear...the rear is already tucking tire a bit...
and i need Jimmy's spacers for crying out loud...or spacers in general to avoid problems in the front...or so i was told...lol
PSN
Old 03-02-2010, 01:04 PM   #617
ericcastro
ericcastro's Avatar
Hammy is trying to adjust it to his driving style.
Hammy is setting the car up to be able to hold onto that drift when it drops out of boost.
So he's putting 50 psi in the tires.
But the trade off is that the car will hit boost and that 50 psi will spin the car out quick.
My opinion is that Steve just needs to learn to keep it in boost, which is alot more difficult on the CA. The boost is only from 5-7K.
And it didnt feel very progressive, so its on or off.
And when its off, 50 psi is not gonna spin 17inch rims with a 1.8L engine.
So I personally would just put Steve out doing donuts and learning how to keep the car in boost and learn to feather the throttle.
Work on the fine throttle control.
Because you cant on and off that throttle like you can a KA.
just my 2 cents.
There are several methods to go at the CA engine it seems.
Or steve should put a different turbo on that is much more pregressive feeling.
Old 03-02-2010, 01:09 PM   #618
mehsilvia
mehsilvia's Avatar
2x4's and trailers are no excuse. Im gonna ram one up ur ass!
Fuck the trailer. You need to focus on the 4 wheels on the ground.
I will work with ya on the adjustments. You do need to know how to handle this shit, and the effects it will have on your driving.
Also. Those spacers i gave Jimmy are shit. They were temps. He promised he would use them as temps. YOU BETTER NOT USE THEM on a track car.
Call JXN for some hub-centric Bolt-ons. Or if you gotta run slip-ons, make sure they are hub-centric and you get the longer wheel studs.
Im serious.
Old 03-02-2010, 01:14 PM   #619
fckillerbee
i say 50, cause that is the easiest for me to learn at....once you get used to the car, dropping tire pressure will only help you get a little more grip. plus, i think we had your tires at 40, and it wasn't "noob" friendly. We can always lower the tire pressure at the track if it's too slippery.
Old 03-02-2010, 01:16 PM   #620
fckillerbee
Im serious.
listen to this man...age is wisdom..unless you are handicapped.
Old 03-02-2010, 01:55 PM   #621
fckillerbee
already posted a wtb for a q45 maf and throttle body, if anyone has one, or know anyone selling one, have them call me/ pm me/ message me/ yell/ whatever....i know people don't check the wtb much.
thanks fellas!
Old 03-02-2010, 02:18 PM   #622
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
just my 2 cents.
i hear you on that...but you got my car to slide via Ebrake...my tree trunk of a leg wont allow it...lol...
ill just buy the tires for the fronts and go wihtout spacers...hows that...
and i hear yah castro, and thats wat im planning, pretty much get my fat ass out there and learn...fine with me...
i believe it was 40r 32f... and yeah ...its easier to drop the pressure than to go up and down the hill to raise it here and there...
i hear em...but fuck me...now i needa get hub centric spacers...sweet part is, i dont know what size...let alone what my offset is...i think i needa buy rims that actually give me a clue on what they are and offset...lol
PSN
Old 03-02-2010, 03:04 PM   #623
CrazyRob
CrazyRob's Avatar
CrazyRob is an unknown quantity at this point
Send a message via AIM to CrazyRob
steve, do u have a blow off valve or recirculating valve?
CrazyRob is offline   Reply With Quote
Old 03-02-2010, 03:13 PM   #624
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
acronym...lol
<3 rob
its BOV...
also... i noticed on the hose the soft hose that goes from the reservoir to pump, its not a stock line, but actually just some hose i bought from AZ...and pretty much were it bend it pinched... which makes me think is another reason why my PS wasnt doing so well...the fluid was getting backed up...
or am i just tripping here...?
PSN
Old 03-02-2010, 03:18 PM   #625
mehsilvia
mehsilvia's Avatar
Um yeah. Bend in line will FAIL fluid system.
If you DID find a bend, thats ur problem. Not the pump.
Old 03-02-2010, 03:33 PM   #626
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
well the pump itself was now aking bad noise...very very bad noise...so luis is already having his guy rebuild it...for extra insurance...and i now have those stock soft lines you brought me back couple weeks back that ill reuse...hopefully that solve that issue once and for all...
PSN
Old 03-02-2010, 03:35 PM   #627
CrazyRob
CrazyRob's Avatar
take off your bov or tighten the fuck out of it
Old 03-02-2010, 03:43 PM   #628
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
^?????? no nintendo...?
PSN
Old 03-02-2010, 03:46 PM   #629
mehsilvia
mehsilvia's Avatar
Shit. I did give you those. Damnit. Mine is leaking
Shoulda kept them - lol
Old 03-02-2010, 03:48 PM   #630
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
well luckuly there not to expensive brand new...which i kinda just wanna do since its a available i think
PSN
